585,886 active members*
5,582 visitors online*
Results 1 to 9 of 9
    Apr 2021
    5
    CNC Programming Help
    Hey all,
    I've been working on this for quite some time and really could use some help/advice. We use discriminator to program these and this practice question has me hitting my head against the wall. The CamInstructer website is pretty horrible in my opinion and have a hard time learning anything from it.
    Apr 2004
    5737
    Re: CNC Programming Help
    Did you mean to attach drawings or something? You're not giving us much to go on.
    Andrew Werby
    Website
    Apr 2021
    5
    For some reason the attachments did not work. Let me try again.
    Apr 2021
    5
    Dec 2013
    5717
    Quote Originally Posted by JoshH3030 View Post
    Hey all,
    What is 'discriminator'. Over all that part does not seem difficult to do the CAM work on, what operation are you having a problem with? Do you have drawing in a .step format?
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2021
    5
    https://imgur.com/W90OO1p
    https://imgur.com/rCCUFA4
    Here is what I have so far, the tough part for me are the triangle pockets and if there is a way to change the diameter of the holes that I drill using g83? The depth of the different circles I am not sure of as well. Just kind of cutting the points and winging it. Any advice would be huge
    Dec 2013
    5717
    G83 is a peck drill cycle. The hole size is not specified in the G code, you only need to load the proper drill for the hole, can be any size.
    Are you hand coding this? Again I'll ask if you have the drawing in a STEP or IGES format.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2021
    5
    Yes I am hand coding this. Honestly the only drawing I have is the one I posted before with all the measurements.
    Dec 2013
    5717
    This should keep you busy for awhile. G code attached.
    Jim Dawson
    Sandy, Oregon, USA
