584,866 active members*
5,215 visitors online*
Results 1 to 6 of 6
    PCNC 1100 vs 770MX ??
    Question: PCNC 1100 vs 770MX ??
    Please hear my use cases out before weighing in.
    So I’ve been pretty dead set on a 1100 but was recently being told that a 770MX might fit the bill. I’m mostly constrained by cost. really don’t want to spend over 15k (all prices assuming ATC, hard requirement). I have a few 1100 options at that price, but haven’t really considered the 770MX. So why not a 1100MX? That would be great, but I have a hard time swallowing 25k for one when I could get a used Haas for that, which we all know would run circles around a Tormach. I know I know, that's a different discussion.
    My use case is as follows:
    1. Cutting steel, brass, bronze, cast iron, and maybe some aluminum. Probably 50% will be steel, so I really want that rigidity. I don’t need crazy tolerances but really would prefer <.005 or .003 at a minimum. Getting tigher tolerances to achieve correct press fits would be a nice plus. Going slow is fine. Ive generally understood the 770 to be far better suited to aluminum since its a lighter, less rigid casting yet has higher speed spindle. I’m way more concerned with accurately cutting steel.
    2. I will be using rapidturn. I already have it, and I will be turning things up to 11” in length using a tailstock. More than likely will leave RT on the bed as I have lots of turned parts to make. Not super sure this will fit nicely on the 770 bed. Am somewhat familiar with Tosa tool. Haven't exhausted assessing their catalog, so feel free to chime in here.
    3. Lots of parts will have tapped holes. I’m not daunted by thread milling, but wondering if the speed of rigid tapping on MX is worth it.
    4. Most parts won’t exceed 11” in length so I’m generally okay with the size in that regard. I will have to make plenty of fixtures which will be slightly larger.
    5. High mix of parts. I'll be making lots of parts in the range of 4-12 in quantity. Should the business grow then of course higher quantity batches, but I'll address that when I get there.
    So, in a nutshell, does the new 770MX casting with BT30 holders provide the same rigidity an older PCNC 1100 does?
    Thanks in advance.
    Re: PCNC 1100 vs 770MX ??
    Feel free to reach out if you have either a PCNC 1100 or 770MX for sale on the west coast. or a smoking deal on a 1100MX :P
    Mar 2012
    189
    I don't think the castings are new on the 770? MX is just servos+bt30 spindle (+extra rpm on 1100), everything else is the same as far as I can tell. Unless you are running small endmills, the extra RPM of the MX won't help you in steel. BT30 with rigid tapping is definitely an upgrade though.
    -Jon
    Jun 2005
    653
    FWIW, when I was deciding, I was told by somebody that had both that I'd be happier with the 1100MX versus the 770MX due to rigidity, even though my work is small enough for a 770 and I liked the reduced footprint.
    Mar 2019
    34
    I have an PCNC 1100 for sale but I’m on the wrong coast.
    Sent from my iPad using Tapatalk Pro
    Jan 2007
    94
    I would lean toward the 1100. A small envelope, when you need something bigger, is a major limitation. The extra room also helps with setups even if you don’t need the travel. Also, rethink the 1100MX. You can scrounge other ways to save money. Make your own cabinet, skip the fancy probes and other toys for now. The only reason to get the smaller machine is if you don’t have room for the bigger one.
  1. Other use for my PCNC 1100
    By rdsi in forum Tormach Personal CNC Mill
    Last Post: 10-13-2017, 09:22 PM
  2. PCNC 1100
    By ConveyTrex in forum Tormach Personal CNC Mill
    Last Post: 12-14-2016, 01:20 PM
  3. PCNC 1100 vs PCNC 770 (Is the 1100 worth it)
    By thunderdork in forum Tormach Personal CNC Mill
    Last Post: 09-21-2016, 08:43 PM
  4. PCNC 1100 help
    By jedge in forum Tormach Personal CNC Mill
    Last Post: 10-23-2010, 11:58 PM
  5. For those of you with a PCNC 1100
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 01-02-2010, 12:51 AM
