585,722 active members*
4,049 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > PlanetCNC_API - DemoCsharp : Can't compile it !
Results 1 to 7 of 7
    I have download the zip file PlanetCNC_API.
    I try to compile the demo in C# but Visual Studio print an error. It can't find the debug target. It generate a file named Demo64d.exe while it should generate a file named DemoCSharp.exe in the __Output folder.
    Have I miss something ?
    Mar 2017
    1304
    Re: PlanetCNC_API - DemoCsharp : Can't compile it !
    Demo64d.exe is correct filename.
    Thanks for your reply.
    I don't why, but the assembly name was "DemoCSharp" when I open the project, and not "Demo64d".
    I change the name and it is better.
    So, I continue my tests and I have a other error. :-D
    Visula Studio don't find the DLL. Should I add it ?
    Mar 2017
    1304
    This is cut/paste from .csproj file
    Code:
      <PropertyGroup>
        <AssemblyName Condition="'$(Configuration)|$(Platform)' == 'Debug|x86'">Demo32d</AssemblyName>
        <AssemblyName Condition="'$(Configuration)|$(Platform)' == 'Release|x86'">Demo32</AssemblyName>
        <AssemblyName Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">Demo64d</AssemblyName>
        <AssemblyName Condition="'$(Configuration)|$(Platform)' == 'Release|x64'">Demo64</AssemblyName>
      </PropertyGroup>
    Make sure that correct dll is referenced in PlanetCNCTNGAPI.cs file:
    Code:
    private const string PlanetCNCLib = "PlanetCNCLib64.dll";
    Ok, I could compile it and start the demo.
    Thanks for your help and your time.
    For others users, I post some explanations & some stuffs I didn't understand.
    - I am working with Visual Studio Community 2013. It seems that Visual Studio didn't care about instructions which are between tags <PropertyGroup>. It is in csproj file but Visual Studio take the name of the project for the executable file.
    - in the PlanetCNCTNGAPI.cs, this is the correct DLL name which is referenced. But Windows can't find it. So I have manually copy the file PlanetCNCLib64.dll from PlanetCNC installation folder to __Output folder for the DemoCSharp.
    Hello Guys,
    I have same problem. I tried above solutions but doesn't work. When I start the program below error occurs. Waiting help please...
    "System.DllNotFoundException: 'Unable to load DLL 'PlanetCNCLib64.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)'"
    Mar 2017
    1304
    Your executable needs to be in same folder as PlanetCNCLib64.dll'
  1. How to compile .wxt to .wct
    By 8c87f24ef3 in forum EdgeCam
    Last Post: 07-18-2017, 12:54 PM
  2. C program compile error
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-01-2012, 01:07 AM
  3. Scripter Compile Error. in:M3. M1s
    By Dan911 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2011, 02:39 PM
  4. compile error, Library not found
    By innova in forum Autodesk
    Last Post: 01-17-2009, 05:22 PM
  5. EMC 2 compile?
    By mkonci1 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:21 AM
