585,715 active members*
3,903 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What step/mm to use for wormgear ?
    Apr 2021
    4
    Hello everyone, so a week ago i've start building my first ceramic 3d printer i've started by building the ram extruder it uses :
    nema 23
    R60 microstep driver
    30:1 gearbox
    1mm pitch screw +nut
    duet 2 wifi
    and my problem is the step/mm or the ram extruder is too high 280000 step/mm
    because of the gearbox.
    When i use 280000 step/mm the extruder extrude the right amount but i won't change speed
    so i've change it to 100 step/mm and i'm thinking change the extrusion factor to 4000%
    What do you guys think ?
    Dec 2012
    199
    Re: What step/mm to use for wormgear ?
    Are you forgetting that the ram movement of 1 mm will give more mm material because the surface of the RAM is bigger than the surface of the nozzle output.
    Nozzle 0.2mm ram 5 mm gives already 625 x more length of material output compared to the ram movement.
    Apr 2021
    4
    yes you're right it dosent need to move that far, but how did you calculate it ?
    i have a 5mm nozzle and the piston is 70mm in diameter
    thank you
    Dec 2012
    199
    Surface of the 5 mm nozle is 2.5 x 2.5 x 3.14 ( Pi ) = 19 mm2 ( roughly )
    Surface of the piston is 35 x 35 x 3.14 = 3846 mm2 ( roughly )
    So one mm movement of the piston will give 3846 / 19 = 200 mm length output ( roughly again )
    Apr 2021
    4
    ok i see, thank you so much for your help
  1. Wormgear 4th axis
    By hokkaju76 in forum Chinese Machines
    Last Post: 01-30-2021, 02:00 PM
  2. Collet/Reducer Help
    By definfected in forum DIY CNC Router Table Machines
    Last Post: 08-18-2015, 02:46 AM
  3. Source for wormgear system-building rotary stage
    By jakovn in forum Linear and Rotary Motion
    Last Post: 11-08-2008, 05:32 PM
  4. Wormgear cutting
    By GEARBUD in forum Uncategorised MetalWorking Machines
    Last Post: 02-08-2004, 07:44 PM
