584,805 active members*
4,854 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Looking for the program for machining eccentric pump piece!!
    Apr 2017
    4
    Hi guys!
    I have CNC turning Mono 250 XL, Technical details of machine is herewith: https://www.macpowercnc.com/products...r/mono-250-xl/
    Refer to this video https://www.youtube.com/watch?v=ZUU9SzFi7F0
    I am looking for the program or method which can help me to machine this part on my machine.
    Is it possible on my existing machine? the guys in the video species that he used macros!
    Part is also attached.
    Waiting for you guys to help!!
    Mar 2009
    1982
    Re: Looking for the program for machining eccentric pump piece!!
    You need the spindle angle controlled as an axis. "C" usually. Sure, the control should be capable to synchronize three axes at once: x, y, z.
    The "Technical Specification" tab indicates very basic data, any details concerning axes control. What it means the line "System" which says Fanuc Oi TF; Siemens 828D and Mitsubishi E80 ?
    I would browse the control settings to discover if there is C axis engagement.
    15362
    Quote Originally Posted by Anurag2973 View Post
    Hi guys!
    This will give you an idea of what your machine will need C axes control is a must so if you don't have a control over the spindle then I don't think it would be possible, this shows a crank shaft being made with the same process. using a Macro means that the user wrote his own program, there is software Cam programs that can do this Gibbs Cam is one of many
    https://www.youtube.com/watch?v=81UjjSH2iFw&t=1s
    Mactec54
    Nov 2007
    351
    Unless that is plastic using an insert like that at that speed on metal with that depth of cut -Dont think so
  1. Replies: 13
    Last Post: 12-02-2020, 09:10 AM
  2. Replies: 0
    Last Post: 11-22-2017, 07:56 PM
  3. Replies: 0
    Last Post: 11-15-2017, 04:19 AM
  4. Machining all of the work piece
    By sdh600 in forum SprutCAM
    Last Post: 05-13-2016, 09:54 PM
  5. Replies: 0
    Last Post: 10-11-2013, 01:10 AM
