585,743 active members*
4,948 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA OSP U100L PARAMETER 3position KEY SWITCH
Results 1 to 8 of 8
    Oct 2018
    101
    would you guys buy these switches from mcmaster carr? ? i need a EDIT LOCK EDIT UNLOCK LOCK switch any idea?
    Oct 2018
    101
    Re: OKUMA OSP U100L PARAMETER 3position KEY SWITCH
    does anyone have a parts book? or a part number? they should all be the same no ?
    Aug 2011
    419
    "Imagination is more important than knowledge."
    Oct 2018
    101
    kUrmay to rescue again. you are full of useful information. thanks, buddy
    Nov 2007
    352
    If you cant find a switch just leave unlocked and protect the programs instead ---better way for sure
    Oct 2018
    101
    Quote Originally Posted by lshingleton View Post
    i think it was in 12 o'clock position when there was no key. but i need to get into parameters somehow.
    like i don't need that to change way lube timing eh? are you familiar with the control ? and parameters?
    Nov 2007
    352
    Yes at one time i worked on them from the control was new i think in 1996 to about 2010 ----------Good controls and we had hundreds of MX40 and MX50/60 Machines and some of the Crown and LS lathes
    Aug 2011
    419
    Here is explanation of edit interlock
  1. Okuma LB300///OSP U100L
    By iffe123 in forum Okuma
    Last Post: 08-25-2023, 04:30 PM
  2. Replies: 3
    Last Post: 04-13-2018, 12:51 PM
  3. Okuma OSP U100L serial on a LB300
    By fomaz in forum Okuma
    Last Post: 04-24-2013, 06:59 AM
  4. Okuma Lathe LU15/OSP-U100L
    By edirig1 in forum Okuma
    Last Post: 12-07-2010, 01:48 AM
  5. Replies: 6
    Last Post: 12-03-2007, 01:32 PM
