585,898 active members*
5,172 visitors online*
Results 1 to 10 of 10
    Compatible encoders?
    Hello! I have a bad encoder for a Fanuc 10T AC servo drive. The glass encoder disk is actually scratched and the print is worn off from rubbing on the photocells. It is a Type A860-0345-T001. I'm having a lot of trouble finding one anywhere. My question is; are there any compatible encoders that have the same disk/internals that I could look for to use for an organ donor? Thanks!
    24221
    Re: Compatible encoders?
    The problem with a sub for a Fanuc AC motor encoder is the encoder also has the commutation track on it which are a proprietary method that Fanuc uses.
    Where are you located, I may have one, would have to check.
    Albert E.
    I'm located in southeast PA
    Hey Al, did you happen to get a chance to see if you had the encoder?
    24221
    No sorry I meant to get back, I don't have that model.
    Albert E.
    Appreciate it, Thanks anyway!
    Apr 2006
    111
    Quote Originally Posted by TimmiTball View Post
    Can you take picture of motor and encoder?
    Quote Originally Posted by tuanpq View Post
    The sticker on the motor is worn away, so I can't get a picture of the part number. But I know it's a 10T/2000 with brake. Here is a picture of the encoder though. And the disk where it is rubbed off.
    Apr 2006
    111
    What kind of machine. Your encoder is high speed and high resolution encoder. This encoder is rare.
    Apr 2006
    111
    You must buy same encoder because your motor have hollow shaft. Screw move through motor.
  1. cheap absolute encoders? Oxymoron? Decent Incremental encoders?
    By mattbesquare in forum Benchtop Machines
    Last Post: 09-09-2010, 12:56 AM
  2. Fanuc encoders compatible with PICO
    By wyobmf in forum Servo Motors / Drives
    Last Post: 03-22-2010, 06:18 PM
  3. VSD compatible ?
    By Johan Cnczone in forum CNC Machine Related Electronics
    Last Post: 05-26-2009, 12:38 PM
  4. gecko compatible
    By dgalaxy in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2006, 05:28 PM
  5. Are CAT and BT compatible?
    By ETNOM in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2004, 02:08 PM
