585,761 active members*
4,200 visitors online*
Page 4 of 6 23456
Results 61 to 80 of 103
  1. #61
    Oct 2009
    733
    Re: David A's Benchtop CNC Version 2
    Final step for completion of the basic machine hardware assembly:
    INSTALLATION OF LINEAR DRIVES:
    The machine uses rotating ball nuts:
    Attachment 465270
    Some specs for the drives:
    • Size: 12mm ball screw
    • Lead: 0.1575" per ball nut revolution
    • Suggested max RPM: 3,000
    • Max speed @ 3,000 RPM: 470 IPM
    • Rotational mass: 4.4 ounces (without bearings)
    • Rotational mass diameter: 1.1"
    • Belt reduction ratio: From 1:2 to 2:1
    • Reduction on the machine: 1:1 on X and Y axis. 1:1.25 on Z axis.
    • Motor size: NEMA 23
  2. #62
    Jul 2018
    6324
    Hi David - You got me excited there I thought you had "real" linear drives but then I looked them up and they are called linear motors...
    https://www.hiwin.us/products/linear-motors/
    Keep at it, Peter
  3. #63
    Oct 2009
    733
    Hey Peter,
    I don't know what you want to call them. I guess every power source driven actuation is a "drive" and every single axis actuation is a "linear drive"?
    I would probably call a linear drive with all necessary gears, belts and supporting parts "drive line".
  4. #64
    Oct 2009
    733
    INSTALLATION OF Z-AXIS DRIVE:
    Remove the bridge on the Z-slide shafts:
    Attachment 465300
    The drive will be installed on those four standoffs:
    Attachment 465302
    Linear drive in place:
    Attachment 465304
  5. #65
    Oct 2009
    733
    With the motor installed:
    Attachment 465312
    Place the bridge over the ball screw and the shafts:
Name:	Linear Drive 6 color arrow.jpg
    Z-axis linear drive installed:
Name:	Linear Drive 7 color.jpg
  6. #66
    15362
    Quote Originally Posted by davida1234 View Post
    Hey Peter,
    What you have is a Ballscrew with a rotating nut, it still a Ballscrew with a driven Ballnut, it is not a linear drive
    Mactec54
  7. #67
    Oct 2009
    733
    Thank you for the clarification, mactec.
    I would correct the header to "ball screw installation" above but the "edit" button is no longer there.
  8. #68
    15362
    It does not really matter how it is called as it is still linear motion using a Ballscrew
    Mactec54
  9. #69
    Oct 2009
    733
    INSTALLATION OF Y-AXIS BALL SCREW DRIVE:
    Turn the ball screw all the way down so that the one end sticks out just about an 1/8" at the ball nut cage:
    Attachment 465376
    Thread the other end of the ball screw through the eye of the big front brace:
    Attachment 465378
    All the way through at the other end, place the motor mount/ball nut cage between the gantry braces:
    Attachment 465380
    Motor mount/ball nut cage in place:
Name:	Linear Drive 11 color.jpg
  10. #70
    Oct 2009
    733
    With the motor mount in place, turn the ball screw all the way in towards the back
    until it sticks out about an inch over the back cap and clears the eye at the front cap:
    Attachment 465384
    Attachment 465388
    Attachment 465390
    Install the grommet into the eye of the front brace.
    Make sure it is seated all the way around:
    Attachment 465392
    Back out the ball screw until it goes through the grommet and clears it by about 1/8":
    Attachment 465394
Name:	Linear Drive 17 color.jpg
  11. #71
    Oct 2009
    733
    For particularly dusty environments, you can place two brush stubs at the front
    and rear of the carriage. They help to clear dust on the non-rotating ball screw:
    Attachment 465398
    Place and screw down the dust covers front and rear on the carriage:
    Attachment 465400
    Screw down the motor mount/ball nut cage with four screws:
    Attachment 465402
    Make sure the rear of the ball screw is placed into the back cap seat:
    Attachment 465404
    Place the clamp onto the screw and tighten down:
Name:	Linear Drive 23 color arrows.jpg
  12. #72
    Oct 2009
    733
    Motor in place:
    Attachment 465426
    Wiring attached:
    Attachment 465428
    Installation of Y-axis ball screw/rotating ball nut is completed.
    Repeat on the A-axis:
Name:	Linear Drive 26 color.jpg
  13. #73
    Oct 2009
    733
    INSTALLATION OF X-AXIS BALL SCREW:
    Install a hex cap screw on the motor plate as shown, leaving
    a clearance of about 1/4" between the hex cap and the plate:
    Attachment 465492
    Push the hex cap/motor plate through the hole and slide to the right:
    Attachment 465494
    Once motor plate/ball nut is placed, install the two bottom screws and start
    tightening while making sure that the ball screw is centered with the grommet eye:
    Attachment 465496
    Attachment 465498
    Two bottom screws tightened down:
    Attachment 465500
    Tighten the hex cap screw behind the cross brace:
    Attachment 465502
    Install and tighten the support brace onto the motor plate:
Name:	Linear Drive 33 color.jpg
  14. #74
    Oct 2009
    733
    As with the other grommet eyes, back out the ball screw to clear the grommet
    eye, install the grommet and turn in the ball screw through the grommet:
    Attachment 465506
    Attachment 465508
    Place the other end of the ball screw onto the clamp pillow:
    Attachment 465510
    Place the clamp on the ball screw and tighten down:
Name:	Linear Drive 37 color.jpg
  15. #75
    Oct 2009
    733
    The installation of ball screws and the mechanical assembly of the machine is finished.
    This will be posted on the website as the base machine on which I am working right now.
    Next up will be all peripheral additions.
    Image of all ball screw arrangements (some drag chains omitted for clarity):
Name:	Linear Drive 38 gradient_color.jpg
  16. #76
    Oct 2009
    733
    Mechanically finished machine from the front:
Name:	Machine_front gradient.jpg
  17. #77
    Oct 2009
    733
    The machine is mechanically finished and ready to accept all your electrics, electronics and peripherals.
    I also designed expansion sets like spindle cooling, cutting fluid or air, dust collection,
    vacuum holding, wiring, etc. which were specifically made for this machine.
    The following posts will show the installation of all the expansion sets.
    SPINDLE COOLING EXPANSION SET
    Spindle cooling set contains two 8-pipe radiators and fans,
    a 200 mL reservoir, a brushless mag-drive, 60 gph pump and hardware.
    This setup has been running for two years on my prototype machine without any problems.
    Parts for water cooled spindle set:
    Attachment 465622
    Set will be mounted on the top plate of the X-carriage:
    Attachment 465624
    Install one side with two screws as shown:
    Attachment 465626
    Looking from the inside:
Name:	EXP Spindle Cooling 4 color.jpg
  18. #78
    Oct 2009
    733
    Install the second radiator/fan the same way on the other side:
    Attachment 465636
    Install the reservoir bracket and the two standoffs:
    Attachment 465638
    Place the reservoir on the standoffs and secure with a zip tie to the bracket:
    Attachment 465640
    Slightly warm up the ends of the 1/4" hose to soften and connect the parts as shown.
    It is a bit tight but the hose will go over the nipples.
    On the prototype machine, it didn't need any clamps to stay on:
    Attachment 465642
    THIS CONCLUDES THE INSTALLATION OF THE SPINDLE COOLANT SET.
  19. #79
    Oct 2009
    733
    WIRING EXPANSION SET:
    Attachment 465964
    Wiring set includes one junction box, three PNP sensors and all necessary signal and power wiring for
    4 servos, the sensors and associated connection wires connecting the machine to your controller.
    The Molex connector ends work with Teknic servos or the ends can be modified to fit other motors.
    Included OMKQN sensors do not require magnets and have been working good on the prototype machine.
    I could not measure any differences between them and the higher end sensors.
    Attachment 465966
  20. #80
    Oct 2009
    733
    Junction box will be installed on the back brace using these holes:
    Attachment 466004
    J-box installed with the spacers.
    On top is a saddle for the reservoir to sit on:
    Attachment 466006
    X-axis limit sensor will be installed onto the slot of the back brace:
    Attachment 466008
Page 4 of 6 23456
  1. David Rigotti - Hobby CNC Plans
    By KeithSloan in forum DIY CNC Router Table Machines
    Last Post: 03-30-2020, 01:51 PM
  2. David A's New 2x3 Bench Top CNC
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 08-18-2019, 01:47 AM
  3. Replies: 1
    Last Post: 03-29-2017, 03:18 PM
  4. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  5. I built My CNC From David Steels Plans Now I need Feedrate help please
    By tager_rot in forum DIY CNC Router Table Machines
    Last Post: 09-09-2007, 07:52 PM
