585,919 active members*
3,303 visitors online*
Page 5 of 6 3456
Results 81 to 100 of 103
  1. #81
    Oct 2009
    733
    Re: David A's Benchtop CNC Version 2
    Install the sensor onto the plastic pad:
    Attachment 466010
    Install the assembly into the slot:
    Attachment 466012
    Screw in the sensor wires and other wiring like the radiator fans, pump
    and controller cable to the corresponding connectors in the J-box:
    Attachment 466014
    Two more sensors and some additional wiring will be attached as more assembly is finished.
  2. #82
    Oct 2009
    733
    First attempt at the new website is published.
    For now, only a few links work, mostly the items discussed in this thread.
    Needs a lot more work. Will add more as other add-ons are finished.
    Let me know what you think.
    Website:
    bryggacnc.com
  3. #83
    Oct 2009
    733
    Y-Axis sensor will be installed here:
    Attachment 466232
    With two screws:
    Attachment 466234
    The steel screw with a T-nut in the channel will trigger the sensor:
    Attachment 466236
  4. #84
    Oct 2009
    733
    Z-Axis sensor will be installed here with two screws:
    Attachment 466238
    The steel flat point set screw will trigger the sensor.
    There are three positions for the set screw to reduce
    unnecessary up and downs of the Z-axis for thin material:
Name:	EXP Wiring 12 color.jpg
  5. #85
    Oct 2009
    733
    Motor wiring installed. Watch for correct colors on the wires.
    Install motors loosely onto rotating ball screw motor mounts.
    The A-axis motor shown here. Others go the same way.
    I use four Teknic CPM-SDSK-2321S-RQN servos for $250 each
    and found them totally acceptable for the prototype machine.
    Attachment 466252
    Each motor mount has a recess at the base of the motor:
    Attachment 466254
    Place the tightening tool into the recess. As you push it in,
    the motor will move up, tightening the belt:
    Attachment 466256
    Adjust for 1/8" "give" of belt with light finger pressure:
Name:	EXP Wiring 16 color.jpg
  6. #86
    Oct 2009
    733
    DUST COLLECTION ADD-ON SET INSTALLATION:
    Dust collection set contents:
Name:	EXP DC 1 color.jpg
Name:	EXP DC 2 color.jpg
  7. #87
    Oct 2009
    733
    Install the base plate to the underside of the spindle mount:
    Attachment 466452
    Looking from the bottom:
    Attachment 466454
    Screw in the LED wires to the terminal as shown:
    Attachment 466456
    LED wires installed:
Name:	EXP DC 6 color.jpg
  8. #88
    Oct 2009
    733
    Place the two Lexan tubes onto the base:
    Attachment 466462
    And slip the manifold over the top of the tubes.
    Fasten the manifold with two screws to the bridge:
    Attachment 466464
    Dust collection set installed:
    Attachment 466466
    Brush ring snapped onto the dust collection base.
    The brush shown here is the open version where you can see the bit
    and the cut area without obstruction. It removes fine dust almost as
    well as a closed brush , leaving a few larger pieces on the material.
    Performance video to follow as soon as the machine is ready to cut.
    There is also a conventional brush ring with full brush coverage:
Name:	EXP DC 9 color gradient brush.jpg
  9. #89
    Oct 2009
    733
    bryggacnc website has been updated with the dust collection page
  10. #90
    Oct 2009
    733
    CUTTING COOLANT SET INSTALLATION:
    Parts for the cutting coolant set:
Name:	EXP Cutting Coolant 1 Lettering.jpg
  11. #91
    Oct 2009
    733
    Remove the screws on the five plugs on the machine bed and pull
    them straight down without turning and twisting them. The heavy
    grease on the bottom of the bed should not be disturbed or cleaned:
    Attachment 466828
    Attachment 466830
    Install the drain nozzles in place of the plugs.
    Hose has a slight curve which should face towards the front:
    Attachment 466832
    Drain nozzles installed:
Name:	EXP Cutting Coolant 5 color.jpg
  12. #92
    Oct 2009
    733
    Hmm, could someone please remove the above post?
    Thank you...
  13. #93
    Oct 2009
    733
    Installation of cutting coolant set is easier if the front of the
    machine is lifted a bit for access. I use a car jack to do that:
    Attachment 466886
    There are two pairs of 80/20 pivot nubs on either
    side of the machine and an additional floating set.
    In this pic, you can also see the five drain nozzles
    which were just installed (blue):
    Attachment 466888
    Slide the floating pair of pivot nubs to about 10"
    of the end nubs. Do not tighten them yet:
Name:	EXP Cutting Coolant 8 color 2.jpg
  14. #94
    Oct 2009
    733
    Install the drawer slide/bracket assemblies to the pivot nubs:
    Attachment 466900
    Pull the slides all the way out:
    Attachment 466902
    The flanges of the cutting fluid basin have pockets for the sliders on the bottom side:
    Attachment 466904
    Adjust the floating slider assembly to match basin width and place the basin onto the sliders:
    Attachment 466906
    Basin portion of cutting coolant set is finished.
    Push the basin to its use position under the machine frame:
    Attachment 466908
  15. #95
    Oct 2009
    733
    Finishing up the outlet side of the cutting coolant set:
    Insert the 1/4" hose into the base of the Loc-Line spout:
    Attachment 466936
    Twist and push the hose all the way in:
    Attachment 466938
    Push the other end of the hose through one of
    the two threaded openings of the dust shoe base:
    Attachment 466940
    The hose will go through a channel in the spindle mount and daylight:
    Attachment 466942
    Pull the hose through all the way and screw in the base of the Loc-Line:
    Attachment 466948
  16. #96
    Oct 2009
    733
    There is a channel in the front cable management:
    Attachment 466950
    Push the hose through the channel and into the drag chain:
    Attachment 466952
    Cutting fluid hose installed:
    Attachment 466954
    Route the hose through the drag chains
    and connect to the cutting fluid pump:
Name:	EXP Cutting Coolant 22 color.jpg
    Installation of cutting fluid set is completed.
  17. #97
    Oct 2009
    733
    Overall arrangement on the spindle side:
Name:	EXP Cutting Coolant 23 color.jpg
  18. #98
    Jul 2018
    6334
    Hi David - Coming along nicely. Your aluminium parts how are they finished? Are they "as made" or some sort of burnishing or tumbling? But not anodised ? Peter
  19. #99
    Oct 2009
    733
    Hey Peter,
    No anodizing at all due to cost.
    Most parts are tumbled, large 1/8" pieces like the rear cross brace are sanded to break the edges.
    The parts have been cut intermittently over two years on a fairly tired machine using mostly drop materials.
    This is meant to be a "proof of concept" build and utilizes a lot of used parts from my first prototype.
    Future production parts will be cut on this new machine.
  20. #100
    Oct 2009
    733
    Bryggacnc website has been updated with the cutting fluid set page.
Page 5 of 6 3456
  1. David Rigotti - Hobby CNC Plans
    By KeithSloan in forum DIY CNC Router Table Machines
    Last Post: 03-30-2020, 01:51 PM
  2. David A's New 2x3 Bench Top CNC
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 08-18-2019, 01:47 AM
  3. Replies: 1
    Last Post: 03-29-2017, 03:18 PM
  4. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  5. I built My CNC From David Steels Plans Now I need Feedrate help please
    By tager_rot in forum DIY CNC Router Table Machines
    Last Post: 09-09-2007, 07:52 PM
