585,663 active members*
3,031 visitors online*
Results 1 to 6 of 6
    Jun 2007
    99
    Tapping in mic-6
    I need to CNC tap 1/4-20 threads through a .75" mic-6 plate. I plan to use a spiral point tap with flood coolant. I usually run at 800 rpm because the numbers are easy to remember. I looked at form tapping but I am afraid it may crown around the hole.
    Form tapping is easiest as there are no chips. Any suggestions and please include RPM. Any special coating Thank you.
    Re: Tapping in mic-6
    I'm all for form taps but on mic6 I prefer spiral cutting taps 800-1000rpm is reasonable . osg make decent taps emuge makes exceptional taps
    Jun 2007
    99
    Thank you.
    In through hole using spiral taps, I will sometimes tap in sections. Such as... drill through part. Tap half. Run drill back through very fast or stop M1 and visually check. Tap the remaining half. Am I being too cautious?
    correct me if I'm wrong but I'm picturing a fixture plate . Sometimes better safe than sorry so I'd say tap at 2 even 3 depths then be done with it . Thats as long as your spindle holds orientation
    Jun 2007
    99
    Thank you very much. Just purchased new taps.
    It sounds very much to me that you should look into thread milling and thread the holes in one go.
  1. mic or tic welder
    By letref in forum Community Club House
    Last Post: 07-01-2013, 06:17 PM
  2. Help configuring MIC-01 cable
    By fanefane in forum Waterjet General Topics
    Last Post: 03-10-2012, 06:36 PM
  3. MIC-6 Cutter Question
    By QSPSB in forum Benchtop Machines
    Last Post: 12-23-2009, 02:34 PM
  4. depth mic issue
    By AlexBanich in forum Calibration / Measurement
    Last Post: 07-29-2007, 12:12 AM
  5. Mic-6 Annealing?
    By NorTyd66 in forum MetalWork Discussion
    Last Post: 09-23-2004, 08:13 PM
