585,665 active members*
3,570 visitors online*
Results 1 to 7 of 7
    7x mc60 motor controller
    Looks like my xmt 1125 kersploded.
    I have a mc60 from a treadmill kicking around, it's for a 2hp brushed DC motor.
    I hooked it up and tried it with no load, seems to work. Rated at 5950rpm vs. The 6000rpm motor in there.
    As long as I keep the stock fuses, is there any reason I can't use this controller? Being pwm it's probably a better setup all in all. Only catch is no tach feedback.
    What am I missing?
    Aug 2006
    671
    Re: 7x mc60 motor controller
    No reason at all. People use the MC60 controller quite frequently. I had one on a Taig mill and ran it for several years like that.
    24220
    The MC-60 is SCR bridge (120Hz) controlled, not PWM, You need the MC2100 version for PWM control.
    There is also a mod on the MC60 that avoids having to take the Pot to zero when ever the motor is stopped.
    Albert E.
    Thanks! I had things wrong there, either way I know what I'm doing today. Surprised this isn't a more common mod on the 7x from what I'm searching over the last few days.
    Alright, works great, lots of torque, lots of blown fuses. Any recommendations? I'm thinking a panel mount breaker (w58 or so)
    Turned down a HSS drill bit shank to fit the largest collet I have for the mill (34mm to 7/8") and it went quite well. Surprised how well the Chinese carbide held up and how the machine could handle .020" passes with only mild discomfort.
    24220
    Odd? The MC60 has built in current monitoring and motor control.
    In the T.M. application it generally uses a breaker.
    Albert E.
    I'm guessing the difference comes in where the current limit is on the TM controller vs the fusing on the lathe. Likely due to the difference in motor sizes. Makes sense that I'd pop a fuse before kicking in the MC60 protection.
  1. Replies: 2
    Last Post: 05-22-2019, 06:41 PM
  2. MC60 treadmill motor - eliminating zero speed start
    By chrismolloy in forum Spindles / VFD
    Last Post: 11-18-2017, 05:00 PM
  3. DC Motor Controller & Driver 2hp ( 2kW ) Treadmill Motor
    By hesham morsy in forum Open Source Controller Boards
    Last Post: 01-27-2014, 12:50 PM
  4. fryer mc60 dropping tools and missing tool changes
    By karl_kunkle in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2012, 07:36 AM
  5. MC60-H CRP 240 ALARM
    By jkrause in forum Okuma
    Last Post: 06-23-2010, 03:20 PM
