puma 8s with a mits. meldas 500 control and a smw space saver bar feeder(pnumatic) I'm trying to figure out what signal the bar feeder is sending at the end of bar,I tryed the /2 block skip thing to run my re-load program, did'nt work, also called the company were the machine came from and they sent me a fax showing a macro call IF[#1000EQ1]GOTO1 N1M98P9001.... I understand the macro, but it don't work, is there a way to check what system varible the bar feeder is using? I'm new to this company and nobody knows anything. thanks for any info.
