585,978 active members*
4,337 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Looking for some agents for portable cnc cutting machine
    May 2007
    11
    Smile Looking for some agents for portable cnc cutting machine
    Portable CNC cutting machine for plasma and oxy-fuel cutting heads Steeltailor
    2-Axis CNC Portable Cutting Machine
    Looking for Dealers, Distributors
    Cut like a big cutting machine with the provided FastCAM software Affordable for all small and medium enterprises Cutting Range: 1200 mm(47")X2000 mm( 78"). Lenght extendable till 6000mm.
    Support both plasma cutter and oxy-fuel cutting torch With its USB port, the data transmission from a PC is as easy as
    downloading photos from a digital camera. SteelTailor has all the performance of a gantry machine.
    An ideal tool for metal work hobbyists, DIY enthusiasts, reparation shops, demolition projects operators, metal scrap yards, street rod chassis builders, machinery works, and others who care about either of the 3 strengths of an oxy-gasoline torch: portability, fuel cost economic, and fuel availability.
    Address: Cannes Industrial Park,No.18,Shuang Qiao Dong Lu, Chao Yang District Beijing 100024,China.
    TeL:+86 10 51662600 51290845
    Fax:+86 10 85370386
    Email: [email protected]
    website:Http://www.steeltailor.com
    MSN: [email protected]
    May 2007
    11
    Encouraged by the tremendous reward from the shows in June, SteelTailor will attend the Fabtech and AWS Welding Show in Chicago later this year. In the next show season starting from October, SteelTailor will be presented in several shows across the world.
    In the first show season of the year between May and June, SteelTailor has been presented in the welding and cutting trade fairs in Moscow, Shanghai, Canada, Poland, Algeria, and South Africa.
    “The Chicago show will be in McCormick Place from November 11-14th, 2007. Our Booth Number is 38023. We look forward to meeting our partners and friends there from all over the world.” said Flora Miao, the President of SteelTailor and oPetrol.
    “We have successfully developed our global distributor partners. We have already distributors in Japan, Canada, USA, South Africa, Algeria, Poland, Ukraine, Guatemala, and Senegal. A few more are on-going under discussion with us from Europe and Asia. “, Said Flora.
    “By attending trade shows, we bring ourselves closer to our distributors and users. What we provide is not only good products but also a great distributor policy. We understand the success of our distributors is the key to our global success”, said Flora.
    Company: Beijing Ess Ltd
    TeL:+86 10 51662600
    Fax:+86 10 85370386
    website:http://www.steeltailor.com
    MSN:[email protected]
    May 2007
    11
    What is Steeltailor P
    SteelTailor P is a portable CNC Cutting Machine.It can cut any complex plane figures as the large-sized gantry CNC cutting machine and support both flame torch and plasma cutter. It is affordable for all enterprises and workshops. The compact design and rational structure make it lightweight,small size and easy to move. It is usable both indoors and outdoors.
    By using high quality controllers in its automation system and antimagnetic materials in its housing, SteelTailor P guarantees a reliable and stable CNC operation.
    The application of the most up-to-date CNC technology allows independent programming from numerical control . equipment failure and maintenance difficulty are reduced.
    The integration of FastCam cutting software makes drawing, nesting and cutting simple and efficient. The software provides high level of material utilization & optimization.
    TeL:+86 10 51662600
    Fax:+86 10 85370386
    May 2007
    11
    Application
    SteelTailor P is an ideal equipment for the small and medium-scale enterprises, SteelTailor P portable CNC Cutting Machine can be widely applied in industries such as automobile,shipyard,locomotive,petrochemical,aviat ion and aerospace,boiler and pressure vessel,machinery,decoration and large-size metallic signs. The cutting and blanking of metal plates such as carbon steel (flame cutting) and stainless steel,copper,aluminium etc. (plasma cutting) can all be peformed by SteelTailor P. It is a replacement of hand-held flame torch,hand-held plasma cutter, profile and pantographic shape cutting machines.
    TeL:+86 10 51662600
    Fax:+86 10 85370386
    msn:[email protected]
    May 2007
    11
    Easy to start,Program and Nest
    Drawing made by the provided FastCAM software is automatically converted into a cutting programme.The FastCAM drawing of part is prepared,nested and directly transformed into cutting-required G-code file after suitable selection of programming parameters. The G-code file is then stored form the PC to a memory key which will be plugged in the USB port of SteelTailor P. The file is loaded and then makes the cutting start.Drawing made using AutoCAD are translated into cutting programme by FastCAM and are directly usable by SteelTailor P.
    TeL:+86 10 51662600
    Fax:+86 10 85370386
  1. Replies: 4
    Last Post: 10-16-2013, 08:18 AM
  2. New products SteelTailor Portable CNC Cutting Machine
    By denniswang in forum News Announcements
    Last Post: 09-15-2011, 04:10 AM
  3. Needed a bench top or portable CNC Milling machine
    By PCCDon in forum Benchtop Machines
    Last Post: 05-02-2007, 04:20 AM
  4. Introduce One Portable CNC Cutting machine
    Last Post: 04-24-2007, 11:13 AM
  5. SteelTailor portable CNC Cutting Machine
    By William0008 in forum Uncategorised MetalWorking Machines
    Last Post: 09-06-2006, 05:17 AM
