586,000 active members*
5,031 visitors online*
Results 1 to 6 of 6
    Aug 2006
    5
    Doosan Z290SMY
    I just purchased a used 2006 Doosan Z290SMY as a starting lathe a few weeks ago. I am a bit worried to learn that Doosan might not carry spare parts for this old Mecatec machine??? Anyone here uses VDI equipped machines and how do they measure up to the BMT type? I mainly machine aluminum but will occasionally do steel and ductile iron.
    Regards,
    Feb 2013
    788
    Re: Doosan Z290SMY
    Doosan prides itself on being able to make or replace every part on every machine they have ever sold.
    On Mecatec, some "never before replaced" parts might have a longer lead-time...but they are available.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Dec 2012
    395
    Re: Doosan Z290SMY
    Hi vdang2k,
    BMT is always better than VDI, ours had double Sauter VDI 30 turrets - 12 station live tools each, the alignment and adjustment of the axial tools is easier on BMT.
    You need some good examples of nc-code to start with, the Blue Book is crap, examples in the book do not work properly.
    Darryl (dhardt) and DougR on this forum gave me in 2014 a good PDF to start with, ..... DOOSAN-MECHATEC-PROGRAMING-MANUAL-OCR.pdf.
    Ask the guys for it if you need it, I still have it and found another one myself.
    I assume you have some CNC skills to start, it's not an easy machine to start with, it's an 8-axis lathe.
    Aug 2006
    5
    Re: Doosan Z290SMY
    Thank you Heavy_Metal for the advice, especially the programming manual part. You don't mind if I will ask you a few things from time to time when I run into problem(s)? I am mainly a milling man & this is my first time running a lathe. I am planning to start off with a few simple projects using only the main spindle and a turret just to get a hang of the machine.
    Aug 2006
    5
    Re: Doosan Z290SMY
    Thank you Darryl. It's reassuring to know there are parts available for an old machine. It isn't the case with Kitamura. Can I trouble you for a DOOSAN-MECHATEC-PROGRAMING-MANUAL-OCR.pdf to get started?
    Feb 2013
    788
    Re: Doosan Z290SMY
    I am in service. I have no programming manuals.
    Another member on this site, Douglas Rizzo, was Doosan's Applications Trainer for many years. he might be able to assist.
    https://www.cnczone.com/forums/members/douglasr.html
  1. Doosan DNM5700S mills and Doosan TT1800SY machines
    By Green0 in forum Daewoo/Doosan
    Last Post: 09-09-2020, 12:30 AM
  2. Doosan
    By STARSR20J in forum Daewoo/Doosan
    Last Post: 01-30-2017, 03:29 PM
  3. Doosan
    By STARSR20J in forum Okuma
    Last Post: 01-27-2017, 03:48 AM
  4. Doosan Z290SMY - " Two Turret Processing "
    By Heavy_Metal in forum Daewoo/Doosan
    Last Post: 02-28-2014, 06:00 PM
  5. Doosan Z290SMY turret problem
    By alesko05 in forum Daewoo/Doosan
    Last Post: 10-05-2008, 02:04 PM
