585,743 active members*
4,796 visitors online*
    Feb 2014
    227
    VMC15 XT Z rails
    Bought a set of Z rails for my VMC15XT. The rails came from Fadalcnc.com. I thought I was buying the original equipment but when they showed up they were PMI rails with carriages attached. There was really no information with how to install them. Called and asked about that but no help. Got on the net found the PMI installation instructions and installed them. They look nice and from what I can tell should work fine. To be honest got a little redass thinking I was buying OEM equipment but was not the case. The carriage oil line fitting threads are 6MM. The original rails were 10/32”. Had to find the right fittings for the PMI rails. I found the right push to connect fittings at source 4 industries. The fittings are all metal not plastic! They were $3.90 each. The fittings can handle up to 400 plus PSI. I will post pictures of the fittings and them installed. Sometimes companies love to sell you parts but have no support after the fact, awesome!
    Dec 2013
    5717
    Re: VMC15 XT Z rails
    The PMI rails probably are Fadal OEM units. They bought them from someone originally, they didn't make them.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2014
    227
    Jim, I understand they did not make them. What I don’t understand is your comment. NSK is what came on the machine from FADAL and that is what I thought I was buying, not PMI. The whole issue was no customer support when I asked for some information on the installation instructions.
    Dec 2013
    5717
    Quote Originally Posted by ballistic42 View Post
    Yeah, that would be a problem.
    Jim Dawson
    Sandy, Oregon, USA
  1. 1998 Fadal VMC15 XT NSK roller rails for X and Y
    By ballistic42 in forum Fadal
    Last Post: 03-27-2021, 03:54 AM
  2. Thomson Bars, V-Rails, or Linear Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-18-2009, 09:39 AM
  3. Hello... moving a VMC15
    By Sherri in forum Fadal
    Last Post: 12-11-2009, 12:59 AM
  4. Vmc15
    By multex1 in forum DNC Problems and Solutions
    Last Post: 04-17-2007, 10:13 AM
  5. Design of plasma table, high rails or low rails?
    By Apples in forum Waterjet General Topics
    Last Post: 12-18-2006, 09:21 PM
