585,556 active members*
3,456 visitors online*
    Apr 2020
    4
    CNC Stepper Motor Source
    Looking for a source for Chinese 6040 X & Axis Stepper Motors. Froze after a year, under "warranty" but no help from seller.
    NEMA 23 frame size 57mm x 76mm, 3A, 200 steps 1.8 degrees, 8 mm main shaft with a 6.35mm rear shaft for handwheel. Any info including correct Nm (oz-in) holding torque appreciated.
    Jan 2018
    1516
    Re: CNC Stepper Motor Source
    Quote Originally Posted by OiUkes View Post
    Been looking for an hour.
    Haven't found anything below 114mm length with 2 different shaft sizes.
    It's either change coupling or change handwheel.
    All I found so far:
    https://www.automationtechnologiesin...haft-with-flat
    https://www.automationtechnologiesin...flat-282-oz-in
    https://www.omc-stepperonline.com/ne...rice&order=ASC
    Jul 2018
    6318
    Hi Oik - Have you checked the motors? They very rarely die...Peter
  1. Motor/Stepper Cable Source
    By Project_Hopeless in forum DIY CNC Router Table Machines
    Last Post: 04-16-2020, 12:48 AM
  2. Power Source selection? for stepper motor driver
    By Drillfeed in forum CNC Machine Related Electronics
    Last Post: 04-05-2013, 01:25 AM
  3. Source for Stepper Motor
    By ecope in forum Taig Mills / Lathes
    Last Post: 09-06-2011, 08:53 AM
  4. need a canadian STEPPER motor source
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 11-02-2007, 05:09 PM
  5. Source of decent, long stepper motor cables?
    By Gerald_D in forum CNC Machine Related Electronics
    Last Post: 04-24-2007, 08:06 AM
