585,932 active members*
3,506 visitors online*
    Sep 2019
    10
    Fanuc 6M, motor Z no move
    Hello, have a Center Moriseiki witth Fanuc 6M control. Can move the X, Y axis, but i no can move the Z axis, but the indicator DRO in screen yes move, but motor Z is stopped. No alarm of servo Z, ENBL1,2 of servo Z closed, alarms OVL1,2 close, VRDY1,2 close. But voltage comand VCMD-EC always is 0.19v. Some idea for what cnc no send comand a servo, or what check should i make ?
    thanks
    Apr 2012
    85
    Re: Fanuc 6M, motor Z no move
    Remaga,
    Sounds like Z axis neglect is on. If position screen for Z changes and no physical motion when in manual/jog/handle.
    DGN 101 bit 5 should be a zero.
    Is there a switch on the operators panel? Z Neglect?
  1. all axis move when motor starts.
    By geckocycles in forum Spindles / VFD
    Last Post: 04-26-2020, 05:20 PM
  2. Move driver to another motor under power?
    By boblon in forum Stepper Motors / Drives
    Last Post: 06-25-2011, 04:12 AM
  3. Replies: 6
    Last Post: 03-14-2011, 09:41 PM
  4. Stepper motor move barely!need help
    By mike3385 in forum Mach Lathe
    Last Post: 09-27-2010, 03:48 PM
  5. How to you make a stepper motor move?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-24-2010, 06:45 AM
