585,764 active members*
4,236 visitors online*
    May 2021
    Laser Tube Size Clarification
    I am getting ready to build a laser cutter based on the plans from FurtherFabrication... I was looking at getting a 130w tube. They are offered in both 65mm and 80mm diameters. The 65 is about half the price. Specs seem to match other than lifetime, which is 8k hours for the 65 and 10k hours for the 80. Outside of price is there any reason to go with one, over the other? Is there any functional difference?
    Also would a CW-5000 be a sufficient chiller for this tube?
    Thanks.
    Re: Laser Tube Size Clarification
    80mm laser tube is recommend for 130w, that should be Reci or Yongli, good brand. Yes, CW5000 chiller is ok for this tube, of course, if it is very hot in your shop in summer, CW5200 will better.
    May 2021
    Thanks for the response, but can you explain why this is the case? That's what I want to understand.
    Because different technology, different production line, different raw materials etc.
  1. As a Laser Tube Manufacturer, How We Test Laser Tube before Shipment
    By SPT-Laser in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-12-2017, 08:12 AM
  2. Laser tube supplier in the UK for chinese laser tube
    By Philjay86 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-24-2016, 08:12 AM
  3. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  4. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
