585,735 active members*
4,692 visitors online*
    Jun 2003
    453
    Mill/Turn lathe servo driven spindle drive?
    Hi All,
    I very much like the concept of the SwissMak and I'm interested in making a slightly larger and more robust version of it.
    My main concern is that I would like to use a large servo motor to drive the spindle but I have doubts that a timing belt would be an acceptable in terms of holding the spindle rigidly enough for milling operations. I don't want to use an inline direct drive because that would mean I could not put long stock in the chuck. I guess an option is an anti backlash split gear. Any thoughts on what may be a suitable means of driving the spindle?
    Splint
    Dec 2013
    5717
    Re: Mill/Turn lathe servo driven spindle drive?
    A belt drive in combination with a disk brake would work well. That's what my lathe has.
    Jim Dawson
    Sandy, Oregon, USA
  1. servo driven lathe turret
    By jschmid in forum Auto Tool Changer
    Last Post: 12-31-2020, 04:06 AM
  2. Need Servo Driven Mill Schematic
    By GPappy in forum LinuxCNC (formerly EMC2)
    Last Post: 11-29-2012, 03:05 AM
  3. Servo driven turn-key linear stage? What's available?
    By danreetz in forum Linear and Rotary Motion
    Last Post: 03-30-2011, 11:37 AM
  4. Spindle is driven via Haas Vector Drive 40/50 Hp
    By tayfunk in forum Haas Mills
    Last Post: 01-31-2011, 07:47 PM
  5. 1kw DC Lathe Spindle - ELMCHAN Servo drive
    By krazatchu in forum Servo Motors / Drives
    Last Post: 04-02-2009, 12:56 PM
