585,991 active members*
4,725 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > RE Mach 3 saving homing position when PC is shut off.
    Mar 2016
    33
    Hi Folks
    Can any one help with MACH3
    I have one machine that is parallel printer port controller 3040 with demo version of mach 3.( this machine only makes one size pocket for over 3 years and dose not need over 500 lines thus demo version of mach 3) it works great with mach3. saves the home position and head position when controller is turned off, Mach 3 is turned off and pc is rebooted.
    I just bought a USB controller 6090 purchased mach3 license. It saves the home position and head position when controller is turned off, Mach 3 is turned off BUT when pc is rebooted. it swaps the home position to where ever the head and gantry is positioned and the home position is adjusted to the distance from the new home it set.
    Why is the USB machine resetting the home when the PC is rebooted. It will save it correctly if the controller and MACH3 are shut down and restarted but not when the PC is shut down. Example: home = (0,0) cutter head is at (10.10) after shutting off the controller and closing MACH3 then turning them on again nothing changes. that is good. >>>> BUT<<<<< if I shutting off the controller and closing MACH3 then re boot the PC home becomes (-10,-10) and cutter head position becomes (0,0)
    Glenn Miller
    Mar 2016
    33
    Re: RE Mach 3 saving homing position when PC is shut off.
    Sorry I posted in the wrong place
  1. More position repeteability sensor when homing?
    By felixpico in forum CNC Machine Related Electronics
    Last Post: 09-05-2019, 03:09 PM
  2. Homing position offset after power cycle (happen randomly)
    By Gerub in forum Servo Motors / Drives
    Last Post: 01-04-2017, 10:53 AM
  3. Fanuc 16M -X axis Homing position deviates.
    By urvesh123 in forum Fanuc
    Last Post: 11-10-2014, 04:06 PM
  4. using encoder index for homing and a axes position
    By rokag3 in forum CNC Machine Related Electronics
    Last Post: 10-16-2009, 12:57 PM
  5. mach homing
    By dertsap in forum Machines running Mach Software
    Last Post: 05-12-2006, 03:42 AM
