The machine is a SV-503/40 with fanuc 18i-m model a
The alarm 410 for z-axis will randomly pop up when I unlock the door or m30 is commanded in a program and the z-axis brake is engaged.
I increased parameter 1829 value a few hundred after observing what the value at DGN was hitting and that seemed to help a lot.
fanuc troubleshooting manual says to check DGN G126 bits 0-7 for '1' when axis is clamped and i get only zeros
can I just increase the parameter 1829 value until this problem goes away without any undesirable side effects? are there any common issues i can check or should i just follow the trouble shooting flowchart?
