585,997 active members*
5,115 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Is there an option to add X/Y/Z limit stops on a Haas controller?
    May 2013
    163
    From time to time when I'm doing a quick manual cut on my Haas super mill I want to be able to set up a soft stop via the control panel... so for example I want to be able to manually move 5.25" in the X direction and when it hits that point it stops.
    I know this can be achieved by writing up some quick code, but I'm just curious if this is possible from the control panel on the machine by using the user coordinate system?
    If i use the Jog lock button and select my direction it will continue till it hits the mechanical limit switches.... so my question is there a way to set a Soft limit to stop at a specific distance or coordinate?
    Kent
    Aug 2009
    1573
    Re: Is there an option to add X/Y/Z limit stops on a Haas controller?
    ...is this what you're thinking "USER TRAVEL LIMITS" in Settings
    https://www.haascnc.com/video/haas-a...rlz5_zqxo.html
    May 2013
    163
    Yes, that is what I am after.... but unfortunately I don't have the next generation controller... which is a bummer...
  1. Can u add a option to config the outputs , inputs of uc400eth
    By Andreiir in forum UCCNC Control Software
    Last Post: 01-18-2017, 05:40 PM
  2. X6-1500GT usb limit switches and stops
    By zedodia in forum Chinese Machines
    Last Post: 04-08-2015, 01:19 AM
  3. Best switch option for limit/homing on G540
    By brandercreative in forum Gecko Drives
    Last Post: 10-12-2013, 09:00 PM
  4. are travel stops required? or are limit switches enough
    By multiplex in forum DIY CNC Router Table Machines
    Last Post: 12-15-2007, 05:11 AM
  5. Add a tangential knife option
    By avengine in forum Community Club House
    Last Post: 04-13-2006, 12:40 PM
