585,954 active members*
4,579 visitors online*
Results 1 to 7 of 7
    Mar 2004
    1542
    axis creeps in MPG mode - Galil card
    When switching to MPG mode (manual pulse generator) the axis has started creeping. machine is two years into a refit and this problem just cropped up.
    There is a standard manual pulse generator wheel with just A+ and B+ channels and of course +5V and ground. There MUST be a line noise problem. I see the A+ and B+ wires are NOT on a twisted pair shielded cable of their own, just asking for trouble.
    It might work to just change to a twisted pair shielded cable, but maybe not. At this point its going to be quite a job to pull in a new cable (conduit is full - need to add another) so I do NOT want to do it twice. Differential encoders are known for FAR more noise immunity.
    i seen this offer for a differential line driver
    https://www.usdigital.com/products/a...rfaces/PC4-H10
    or
    https://cdn.usdigital.com/assets/dat...68589686344445
    Has anyone ever used this product or something similar? Or is there a better route?
    Karl
    Dec 2013
    5717
    Re: axis creeps in MPG mode - Galil card
    I have used those US Digital line drivers before. They do work.
    But before you do that, try pulling the A/ and B/ to either 5V or GND on the Galil, I normally use a 1K resistor for this.
    If you go into the Galil terminal software you should be able to watch the drift on the counter for the axis you have the MPG connected to.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2004
    1542
    Thanks for the great idea. i will try this today.
    What about a very small capacitor on the signal lines? Pulses are only maybe 4 per second maximum.
    24221
    Karl mentions just A & B channels as in my experience that is what most MPG's have, I would also decouple the 5v supply with a ~10µf capacitor at the MPG, could be picking up some pulses from noisy source, generally shielded cable is used also.
    Albert E.
    Dec 2013
    5717
    You could try a capacitor, Al's suggestion is good also.
    I was suggesting pulling the Galil end of A/ and B/ high or low rather than the MPG end.
    Another option is to get a MPG that has a 4 channel output. That's what I use.
    https://www.ebay.com/itm/19371017463...EAAOSwKWJfh-wo
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2004
    1542
    OK tried the resistors, made MPG drift much worse. Almost continuous run or jog.
    I had been working on a scale for the knee. This problem came up while doing that. i noticed the +5V and common laying right beside the A+ and B+ signals. moved these wires and problem went away. I now note if in MPG and I move the knee, that axis begins drifting. So, I won't do that.
    It would be best to run a shielded twisted pair wire but the conduit to the operator panel is full, no way to pull in another without removing the whole bunch and pulling all in at once. So, I'll just say a quick prayer and hope problem just goes away. My luck on just hoping has not been that good. I'll bet this comes up again right when doing a critical rush job.
    Dec 2013
    5717
    Add a conduit maybe?
    Jim Dawson
    Sandy, Oregon, USA
  1. New Motion card from GALIL
    By Al_The_Man in forum Controller Cards
    Last Post: 12-01-2020, 07:19 PM
  2. Replies: 0
    Last Post: 08-11-2015, 10:05 PM
  3. 21-M false encoder readings in MPG mode
    By meadowtech in forum Fanuc
    Last Post: 03-12-2009, 09:11 PM
  4. How to measure with a Galil card...
    By REVCAM_Bob in forum Controller & Computer Solutions
    Last Post: 10-17-2008, 07:04 PM
  5. Camsoft to 1030 Galil card
    By jimtom in forum CamSoft Products
    Last Post: 09-02-2007, 09:59 AM
