547,486 active members*
1,520 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Weird Toolpath
    May 2021
    Weird Toolpath
    Hello! I want to cut a Profile of a Double-Bass-Bow. The head is scanned with an 3D Scanner and I constructed a Stick for it. Now I marked the edge wich lies on the Table. If I use the command "Profiling", it does this: MADCAMBUG.jpg (60.4 KB).
    How can I fix the toolpath?
    Registered
    Oct 2013
    16
    Re: Weird Toolpath
    To me it looks like your profile curve may not be a closed curve...
    Member
    Aug 2005
    203
    Re: Weird Toolpath
    From my experience using Rhino, when generating curves (depending on how you do it), there can be remnants of scanned points or lines left that occupy the same drawing space as the spline you've just created. Or if you've generated several line segments, but haven't joined them before post processing. When assigning tool paths, the software may pick up those remnants/disconnected line segments instead of the spline. The result is retracts where there should have been continuous cutting. Try selecting/deleting portions of the spline as a means of preserving just the spline and then assigning the tool path. Also, you'll want to join all additional geometry that wants to be part of a single toollpath.
    Hope this helps.
    Registered
    Feb 2006
    178
    Re: Weird Toolpath
    The curve that you are selecting for the profiling toolpath doesn't seem to be smooth enough. It probably includes some kinks that will reverse the direction of the curve at some places. Try to use the curve rebuild command in Rhino before selecting the curve for the profiling toolpath.
    /Joakim
  1. Replies: 0
    Last Post: 03-09-2021, 10:50 PM
  2. Weird rotary movement with fusion wrapped toolpath
    By ubergeekseven in forum Avid CNC
    Last Post: 09-24-2019, 04:12 PM
  3. Replies: 4
    Last Post: 10-20-2016, 11:45 AM
  4. Weird problem with abbreviated toolpath
    By wpflum in forum Machines running Mach Software
    Last Post: 03-15-2010, 01:39 PM
