586,000 active members*
4,834 visitors online*
    Jun 2019
    Mazatrol 640t buttons not showing
    Hi folks! I have a problem right now with mazatrol software. The problem is that the battery behind the screen in the panel died so I changed it. I did this procedure while the lathe was on because I thought that doing this procedure while the lathe was off would make me lose the parameters, that after restarting the lathe happened whatsoever. Then, I was willing to fix the parameter error but no buttons appear in the software... I don't know why and I double checked the emergency stop buttons, the one in the panel and the one in the handwheel control. I hope anyone can help me! I attached some pictures so you can see what's currently going on! Thanks in advance for taking the time to read me!
    Sep 2021
    Re: Mazatrol 640t buttons not showing
    Hello,
    Did you get this fixed? I am having the same problem. All I'm getting is "26 illegal parameters"
  1. BACKUP MAZATROL 640T
    By emersonja in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-16-2020, 06:58 PM
  2. Mazatrol Fusion 640T
    By Velez in forum Questions or Problems
    Last Post: 10-19-2018, 07:14 PM
  3. Mazatrol Fusion Nexus 640T
    By jerryk2221 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-04-2014, 05:04 PM
  4. Mazatrol 640T
    By Doubleddaved in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2012, 07:17 PM
  5. Parameters Mazatrol 640T
    Last Post: 03-07-2012, 02:37 PM
