585,752 active members*
4,035 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > FANUC Motor pulse generator question
    My J325 has a Fanuc spindle motor with a pulse generator, I am wondering if it can be connected to my Unidrive for closed loop vector mode.. Based on the photo it has A A/ B B/ com and 5 vdc connections - no index
    Attachment 463950. I believe pulse generators don't output a square wave but somehow Tree used it with their spindle drive.
    Re: FANUC Motor pulse generator question
    Should be not compatible.
    Quote Originally Posted by lavrgs View Post
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    24220
    By pulse generator, I assume you mean encoder?
    Pulse generators are generally the term used for them in hand-wheels.
    That appears to be a standard quadrature encoder, not the typical Fanuc encoder used in the servo's as these have a proprietary commutation method.
    You most likely can use it where you would any other quadrature encoder.
    Albert E.
    When you say it appears to be a standard quadrature encoder I assume that's based on the signals shown. I call it a pulse generator because that's what Fanuc calls it on the label , it's just there to confuse me 9-) - I will try hooking it up and what the signal looks like on an oscilloscope.
    24220
    For a quadrature encoder, you should have two square waves 90° apart A & B , you should also have their complements. /A & /B.
    Albert E.
  1. Motor Fanuc
    By valvulin in forum Spanish
    Last Post: 01-25-2014, 04:03 AM
  2. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  3. need FANUC motor
    By recycleroy in forum MetalWork Discussion
    Last Post: 09-22-2006, 03:54 PM
  4. Fanuc motor ???
    By jevs in forum Servo Motors / Drives
    Last Post: 03-16-2005, 11:47 PM
