545,756 active members*
2,168 visitors online*
IndustryArena Forum > CAD Software > Logic Trace CNC/DXF > flying owl graphic for the vinyl cutter
Results 1 to 2 of 2
    Member
    Oct 2007
    837
    printed this image full sized and trace it out to create a *.dxf file for the vinyl
    cutter to cut out, then mount this vinyl cut out on a white substrate
    https://youtu.be/Qywnsyv0Tug
    Member
    Jun 2021
    3
    Re: flying owl graphic for the vinyl cutter
    I own some 3D printer I have built myself (most recent being Voron 2.4), I have a CNC (using MPCNC, now a PrintNC), now I look to build the Vinyl cutter... but in the DIY scene I can't find anything and I wondered why there's nothing?
    I might begin to design a one, but I don't have any experience with a Vinyl Cutter (since now, the feeder rollers alone are a problem, the rest axis Z and X seems very easy.)
  1. small graphic printed, digitized and cut from vinyl
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 02-27-2020, 09:19 PM
  2. digitizing a snow plow picture and cutting as a vinyl graphic
    Last Post: 01-31-2020, 01:33 AM
  3. tracing a graphic and cutting it out of vinyl
    Last Post: 11-01-2019, 04:45 PM
  4. tracing a graphic design for a vinyl cut
    Last Post: 07-01-2019, 08:40 PM
  5. Digitize a paper diagram to create a vinyl graphic display
    Last Post: 05-11-2019, 06:39 PM
