585,930 active members*
3,906 visitors online*
Results 1 to 2 of 2
    Fixed gantry Router made of steel
    I did a video on how I built my fixed gantry router mostly made of steel:
    https://youtu.be/IsVqWVxyB5g
    Jul 2018
    6334
    Re: Fixed gantry Router made of steel
    Well done! Excellent build and thanks for the info. The more videos the better... For steel cutting with that spindle are you using "normal" chipload for steel and cutting faster or trial and error? Seems no vibration issues, the thick sections do the trick... If you are interested and capable if you could test the XYZ static stiffness of your machine that would be excellent information for us designers out here....Peter
  1. 4' x 4' x 9" Welded Steel Frame Fixed Gantry CNC Router
    By Dillsnap759 in forum CNC Wood Router Project Log
    Last Post: 12-02-2020, 10:06 PM
  2. Fixed Gantry for Steel/Aluminum
    By QsDesign in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2020, 10:15 PM
  3. steel/aluminium fixed gantry build
    By v2tiller in forum DIY CNC Router Table Machines
    Last Post: 06-16-2020, 09:42 AM
  4. Lessons in overkill! Welded steel, fixed gantry router
    By mcentric in forum DIY CNC Router Table Machines
    Last Post: 10-23-2018, 08:53 AM
  5. Fixed Gantry Steel, wadeodesign
    By wado1971 in forum DIY CNC Router Table Machines
    Last Post: 01-06-2018, 02:12 PM
