585,722 active members*
4,106 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need Spindle Recommendation for Cutting Stone
    May 2021
    The boss purchased an Off-Brand 3 axis CNC router for our stone business. The spindle failed with very few hours of use. Seems like the bearings failed. The spindle has no NEMA rating, probably has too little torque, and we suspect it isn't built to handle the special rigors of cutting stone. We'd like to replace the spindle with a more robust, properly rated unit. I am attaching the spec for the defective spindle. Any help will be appreciated. Thanks in advance !
    Re: Need Spindle Recommendation for Cutting Stone
    Suggest Choose China 5.5kw cosntant water cooling spindle +water cooling system .
    This type spindle is main for stone and aluminum .
    Omni cnc stone router engraving and cutting Marable tombstone3
    https://youtu.be/DHvYPfnm3mo
    May 2021
    Quote Originally Posted by allencncrouter View Post
    Thank you, allencncrouter
    15362
    Quote Originally Posted by 0aw0 View Post
    You should not consider anything from this supplier
    Mactec54
    May 2021
    thank you, Mactec54
  1. spindle recommendation for cutting mild steel
    By eloid in forum Spindles / VFD
    Last Post: 05-27-2016, 09:28 PM
  2. Replies: 1
    Last Post: 11-09-2015, 02:36 PM
  3. Spindle/Motor recommendation for cutting HDPE tube
    By indycobra1 in forum Uncategorised MetalWorking Machines
    Last Post: 08-07-2015, 04:00 PM
  4. Water jet cutting machine for cutting glass stone metal
    By sinowaterjet in forum News Announcements
    Last Post: 07-16-2014, 07:48 AM
  5. Spindle+VDF recommendation for long jobs cutting 18mm Plywood below €1000
    By javito in forum DIY CNC Router Table Machines
    Last Post: 05-17-2013, 10:27 AM
