585,676 active members*
5,091 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Calmotion USB wont run whole program
Results 1 to 15 of 15
    Oct 2006
    157
    I need some help guys. My new to me 1988 Fadal 4020 has been a work in progress. But I can run a short program from the Calmotion USB but not larger programs.
    At first I thought it was my Fusion 360 putting out strange code but I had a professional check it out and he said the code was good.
    So basicaly it will stop short then jump back to the beginning of the program and start from the beginning.
    Any ideas ?
    Baud rate is set correct -9600
    CD,8 (enter)
    DNC, 1008.txt+
    Is how I get the controler to read it.
    Looking for suggestions.
    Calmotion USB was baught new Oct 2020
    Thanks!
    Aug 2009
    1570
    Re: Calmotion USB wont run whole program
    ...some things are not allowed in Programs when running DNC. Like no SubProgram calls or Looping maybe causing the problem.
    Read more Chapter 14.2.4 (page 342)
    https://fadalparts.net/content/Fadal...r%20Manual.pdf
    Oct 2006
    157
    MachineHop5,
    Thanks for the reply . I made sure I didn't have any sub routines or Looping - I understand they will confuse it.
    15362
    Quote Originally Posted by AirChunk View Post
    MachineHop5,
    Post you program just cut and paste the area where there seems to be a problem
    Mactec54
    Oct 2006
    157
    Its somewhere around line 2800.
    Its part of the engraving portion.
    Thanks!
    N2725 X-2.3838 Y-0.4161 Z-0.0127
    N2730 X-2.3782 Y-0.4117 Z-0.0128
    N2735 X-2.3725 Y-0.4065 Z-0.0129
    N2740 X-2.3669 Y-0.4006 Z-0.013
    N2745 X-2.3614 Y-0.3939 Z-0.0132
    N2750 X-2.3562 Y-0.3867 Z-0.0135
    N2755 X-2.3513 Y-0.3789 Z-0.0137
    N2760 X-2.3469 Y-0.371 Z-0.0139
    N2765 X-2.3429 Y-0.3624 Z-0.014
    N2770 X-2.3392 Y-0.3531 Z-0.0141
    N2775 X-2.3365 Y-0.3447 Z-0.0143
    N2780 X-2.3347 Y-0.3379 Z-0.0144
    N2785 X-2.3329 Y-0.329
    N2790 X-2.3317 Y-0.3198 Z-0.0145
    N2795 X-2.331 Y-0.3103
    N2800 X-2.3308 Y-0.3002
    N2805 X-2.3311 Y-0.2911 Z-0.0144
    N2810 X-2.332 Y-0.2823 Z-0.0143
    N2815 X-2.3333 Y-0.2743 Z-0.0141
    N2820 X-2.3352 Y-0.2666 Z-0.014
    N2825 X-2.3371 Y-0.2608 Z-0.0139
    N2830 X-2.3399 Y-0.254 Z-0.0138
    N2835 X-2.3426 Y-0.2487 Z-0.0137
    N2840 X-2.3461 Y-0.2434 Z-0.0136
    N2845 X-2.3502 Y-0.2382 Z-0.0134
    N2850 X-2.3538 Y-0.2343 Z-0.0133
    N2855 X-2.3579 Y-0.2306 Z-0.0131
    N2860 X-2.3628 Y-0.2268 Z-0.0129
    N2865 X-2.3673 Y-0.224 Z-0.0127
    N2870 X-2.3722 Y-0.2216 Z-0.0125
    N2875 X-2.3774 Y-0.2195 Z-0.0123
    N2880 X-2.3837 Y-0.2176 Z-0.0122
    N2885 X-2.3896 Y-0.2164 Z-0.0121
    N2890 X-2.3976 Y-0.2153 Z-0.0119
    N2895 X-2.4072 Y-0.2146 Z-0.0118
    N2900 X-2.4194 Y-0.2142 Z-0.0117
    N2905 X-2.423
    N2910 X-2.4671
    N2915 X-2.4716 Y-0.2146 Z-0.0121
    N2920 X-2.4761 Y-0.2157 Z-0.0132
    N2925 X-2.4806 Y-0.2174 Z-0.0149
    N2930 X-2.4927 Y-0.2025 Z0.
    N2935 X-2.4806 Y-0.2174 Z-0.0149
    N2940 X-2.4821 Y-0.2212 Z-0.0142
    N2945 X-2.4832 Y-0.2251 Z-0.0139
    N2950 X-2.5236 Y-0.4183
    N2955 X-2.5242 Y-0.4225 Z-0.0142
    N2960 Y-0.4268 Z-0.015
    N2965 X-2.5238 Y-0.4312 Z-0.0163
    N2970 G0 Z0.225
    N2975 G1 X-2.2907 Y-0.4475 F100.
    N2980 G0 Z0.2
    N2985 G1 Z0. F20.
    N2990 X-2.2737 Y-0.4336 Z-0.0139
    N2995 X-2.2625 Y-0.4475 Z0.
    N3000 X-2.2737 Y-0.4336 Z-0.0139
    N3005 X-2.2532 Y-0.3356 Z-0.0138
    N3010 X-2.252 Y-0.3312 Z-0.0142
    N3015 X-2.2501 Y-0.3269 Z-0.0151
    N3020 X-2.2475 Y-0.3227 Z-0.0168
    N3025 X-2.2482 Y-0.3178 Z-0.0151
    N3030 Y-0.3131 Z-0.0141
    N3035 X-2.2476 Y-0.3085 Z-0.0138
    N3040 X-2.2299 Y-0.2241
    N3045 X-2.2289 Y-0.2206 Z-0.014
    N3050 X-2.2276 Y-0.2171 Z-0.0146
    N3055 X-2.2395 Y-0.2025 Z0.
    N3060 X-2.2276 Y-0.2171 Z-0.0146
    15362
    Thanks!
    N2905 X-2.423
    N2910 X-2.4671
    N2970 G0 Z0.225
    N2980 G0 Z0.2
    N2985 G1 Z0. F20.
    It might have lost it's Feed rate, should not have, the program looks ok, so you could try by adding some feed rates in that area
    Or the program may be to long for the control to run it, if so you may have to break up the program
    Mactec54
    Aug 2009
    1570
    ...If your machine has DNCX try using that command. If not, I would suspect the cable between the Calmo and the RS232 plug. First check the grounding lug on the RS232 plug to Cabinet by removing it and scraping the paint off so there is no questions about good grounding. Also try/check in the parameters (SETP) for Buffering that it is set max 255.
    good luck
    Oct 2006
    157
    Thanks man . After talking to Calmotion today they wanted the whole unit I bought from them back . They helped me do some troubleshooting and they think the firmware in the Calmotion black box was corrupted. So I sent it back to them to be fixed .
    Ill report back after it returns to see if it works properly.
    Aug 2009
    1570
    ...would have been nice if, they just send you a new unit... or better yet personally showed up to fix it. we wish
    Oct 2006
    157
    Machinehop5,
    Yeah it would of been really good if they would of just exchanged it for a good one.
    The lady out there said it would only be a couple of days to fix it. But Now I am at the 2 week mark since they recieved it and I am still waiting .
    Grrrrrrr
    Jun 2021
    I have the calmotion and I have not had problems. I recommend it. I generate codes with mastercam. I think you should use the .nc extension it would look like this. cd, 8 dnc.1000.nc + the program should start like this. or 1000;
    Oct 2006
    157
    Still chasing issues - How big/how many lies of program have you ran?
    Oct 2008
    1632
    I never had any luck with my Calmotion either. Short or fairly small programs were okay, but larger ones gave me problems. Contacting Calmotion really didn't help in my case and I simply unplugged mine and quit using it. I hope they get you fixed up.
    Oct 2017
    4
    i had this problem before as wel
    there is the settings file on the calmotion try to put the baud rate you will be using in there as well that worked for me
    now I can run programs with 100k more lines no problem
    if you'd like i can share my settings file of my calmotion card
    i can now run adaptive programs no problem only very small vast movement then it will struggle a bit but still work
    hope this wil help
    Mar 2008
    683
    Check grounding. I had a heck of a time in my previous shop with intermittent problems. All was traced back to bad grounding. In my new shop with new wiring I haven't had a problem.
  1. G72 and G70 wont both run in the same program
    By johntlarson in forum NCPlot G-Code editor / backplotter
    Last Post: 04-24-2021, 03:16 PM
  2. Calmotion USB.
    By neilthib in forum Fadal
    Last Post: 07-02-2020, 12:26 AM
  3. Mach3 wont run entire program
    By Murphy_ia in forum Mach Software (ArtSoft software)
    Last Post: 01-21-2015, 04:38 PM
  4. shark jog ok but wont run program
    By router101 in forum Mach Mill
    Last Post: 02-07-2011, 11:02 PM
  5. program wont run
    By laamar in forum Bridgeport / Hardinge Mills
    Last Post: 02-27-2008, 08:39 PM
