585,749 active members*
3,698 visitors online*
Results 1 to 8 of 8
    May 2021
    RFQ for machined and fabricated parts
    Hello.
    I am new to this forum (retired mechanical engineer), but was referred as a possible source for CNC work. If interested, please quote price and delivery on the following parts:
    PUTU001 - qty 2
    PUTU002 - qty 2
    PUTU003 - qty 2
    PUTU004 - qty 16
    PUTU005 - qty 2
    PUTU008 - qty 2, composed of:
    - PUTU006 - qty 1
    - PUTU007 - qty 1
    PUTU011 - qty 2, composed of:
    - PUTU009 - qty 1
    - PUTU010 - qty 1
    PUTU014 - qty 1 composed of:
    - PUTU012 - qty 1
    - PUTU013 - qty 1
    Some notes:
    - If your shop doesn't have the capability to do the welding, please consider quoting the individual pieces. I may be able to source welding elsewhere.
    - CAD files are available upon request. Formats available are:
    - 3D formats - SolidWorks (2011), STEP
    - 2D formats - SolidWorks, DWG, DXF
    - Please don't let the presence of GD&T discourage you from quoting. GD&T is simply a convenient language to convey the part requirements. If you are unfamiliar with any particular GD&T callouts, please let me know. I'd be happy to clear up any questions you may have.
    - All materials, including the 4130 steel sheet and tubing are available from McMaster. You may have an alternate source of supply.
    - Please let me know if you find any errors or omissions which would cause problems quoting or manufacturing.
    - Thank you for considering this package of work! I look forward to hearing from you.
    Thank you,
    Mike
    Mar 2015
    47
    Re: RFQ for machined and fabricated parts
    Greetings,
    Looking at the parts using 4140 steel, I did not see any heat treat requirements. Is the material to be in the annealed state?
    Cheers,
    David
    May 2021
    Thank you for your question. The alloy is 4130 (aka chromoly). Either annealed or normalized is OK. No subsequent heat treating is required.
    Thank you,
    Mike
    Quote Originally Posted by fc60 View Post
    Greetings,
    Cheers,
    David
    Apr 2012
    51
    Are you still looking to get this quoted? Can you provide a contact email or turn on PM?
    Br
    Mar 2015
    47
    Greetings,
    Just started a new work package and will not bid on your project.
    Cheers,
    David
    PS My profile says Private Messaging in ON?
    May 2021
    Hello,
    I'm sorry...I was unaware PM was off. I believe that is corrected now and will also send you a PM with my email.
    Thank you.
    Jun 2021
    Hello, I am coco from China, our company has 16 years of non-standard parts processing experience, looking forward to your reply! Follow up need to quote can also find us, thank you
    Nov 2021
    Will you consider a China machining shop?
    Contact me if you want [email protected]
    Jun 2023
    20
    Quote Originally Posted by mcencula View Post
    Hello.
    PUTU001 - qty 2
    PUTU002 - qty 2
    PUTU003 - qty 2
    PUTU004 - qty 16
    PUTU005 - qty 2
    - PUTU006 - qty 1
    - PUTU007 - qty 1
    - PUTU009 - qty 1
    - PUTU010 - qty 1
    - PUTU012 - qty 1
    - PUTU013 - qty 1
    Some notes:
    Thank you,
    Mike
    Hello,
    Hope you are doing well!
    This is Eva, Project Manager of Best Prototypes, a reputable prototype manufacturer in China. I am writing to see if there are any possible for us to be your supplier?
    We have the services for your parts.
    -CNC machining (3 axis. 4 axis. 5 axis).
    -3D printing (SLA, SLM, 3DP,FDM).
    -Vacuum Casting (silicone Mold),
    -Fast Tool / Die casting.
    -Machining (Bending,Punching,Cutting,Welding).
    -Injection mold
    If you have projects that need to quote, you can send it to my email, then attach the materials, quantity, process and finish you want.
    I will give you a free quotation as soon as possible.
    Kind Regards,
    Eva.
    Email address: [email protected]
  1. Replies: 3
    Last Post: 10-25-2013, 08:00 AM
  2. Replies: 5
    Last Post: 03-14-2013, 05:18 PM
  3. RFQ Machined Polyethylene parts
    By MnelsonHPS in forum RFQ (Request for Quote)
    Last Post: 07-22-2012, 07:10 PM
  4. RFQ for 2 machined parts
    By automationsteed in forum Canadian Club House
    Last Post: 06-12-2011, 02:23 PM
  5. RFQ for 2 machined parts
    By automationsteed in forum Employment Opportunity
    Last Post: 01-13-2011, 02:48 PM
