585,599 active members*
3,572 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > End Taper Angle Sherline Mill Leadscrew
    Aug 2004
    50
    I'm converting an old Sherline mill to CNC. Seems this example is old and does not have the three piece leadscrews like more modern versions. My lead screws are all one-piece. I'm using Sherline couplers so this needs to be tapered.
    Do any of you folks know the angle? Or can somebody perhaps measure a spare rod on-hand? I can machine the taper and threads on the end. Just need the specs.
    It's the end of the leadscrew as shown in this image circled in blue:
    Thank you.
    Mike N
    No good deed goes unpunished.
    Jul 2013
    5
    Re: End Taper Angle Sherline Mill Leadscrew
    Sherline will sell you a tapered cnc ready leadscrew for about $19/axis. If you can’t find what you need online, just call them. They’re really helpful.
    I have a Sherline Mill that I bought in 2008 and converted to CNC. I just finished the GRBL control box and I’m testing now.
  1. Leadscrew cover for your Sherline mill
    By chuck.yeo in forum Benchtop Machines
    Last Post: 03-03-2019, 01:17 PM
  2. Taper mill angle
    By claudiu220405 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-23-2013, 04:46 PM
  3. Morse Taper End Mill Holder
    By zerodegreec in forum Uncategorised MetalWorking Machines
    Last Post: 02-23-2013, 02:23 AM
  4. CAM software setup for Sherline mill with 4th axis at an angle?
    By PaulMakesThings in forum Benchtop Machines
    Last Post: 10-18-2011, 03:12 AM
  5. Difference in Female Taper angle using Taper Cutter
    By Buntron in forum Material Machining Solutions
    Last Post: 06-07-2011, 06:53 AM
