585,987 active members*
4,623 visitors online*
    Breakout board advise please
    I acquired an old 4x8 cnc router and after installing mach3 on an old windows xp desktop and buying a C10 bob I finally got things going. I drew my first project in vectric aspire and cut for 15 hrs with no problem. I shut everything down that night and the next day my z and x axis only move in one direction.
    I checked wires and swapped things around finally found that changing pins on the breakout board fixed the problem.
    So my questions are #1. what is the best thing to replace this bob with? This is a big heavy machine (5000 lbs)? all 3/16 steel construction including the gantry. #2 I currently have both nema 34 x axis motors on separate drivers but same pins on the bob, should I change that? I would like to get something with a relay to control on/off for dust collector.
    I would also like to eventually add a rotating axis and vacuum pumps for the existing vacuum table that I am currently not using due to no pumps.
    I am open to any suggestions, usb, ethernet? I dont really know anything about this other than what I've taught myself through the process of rebuilding this machine.
    Thanks in advance for any help
    Shane
    24221
    Re: Breakout board advise please
    Not sure why it would not work, the C10 can be set for sink or source inputs, did you have these right?
    Can you post a diagram of sorts?
    Albert E.
    Everything did work, I jogged everything around just playing with mach3 for a week or so and then it cut perfectly for about 15 hrs. I shut down the machine and computer and the next day z and x were not moving correctly, changing the output wires to z and x to different pins and everything works again. I'm not sure what you mean with sink or source inputs?
    24221
    Page 5 & 6 of the manual explains it.
    Albert E.
    Now that I look at that again I do remember reading that, at the time I didn't understand what it was talking about. I have it set to pull down but I'm not using any inputs on the breakout board if that matters. I have 2-9 set to pull up and com set to ground.
  1. GRBL Uno Breakout Board / Shield Board
    By CScotty in forum Arduino
    Last Post: 05-07-2021, 07:49 AM
  2. motion control board (breakout board ) which one to buy??
    By rmachinist in forum Benchtop Machines
    Last Post: 12-23-2019, 03:45 PM
  3. UC100: Advise on DB25 Breakout Board *With* Built-in Stepper Drivers
    By Bravin Neff in forum UCCNC Control Software
    Last Post: 02-24-2019, 01:24 PM
  4. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
