585,967 active members*
4,449 visitors online*
    Sep 2003
    1469
    Replace Bearings Hityachi M12CV
    I need to replace the bearings on my Hitachi M12CV router. i have it stripped it down to where I have removed the left hand top nut and attached magnet.
    All the screws are out and i hesitate to put any uneducated force on the remaining assembly.
    Hope someone that has experience in this area can help.
    Hager
    Apr 2018
    133
    Re: Replace Bearings Hityachi M12CV
    You may find this pictorial how-to useful:
    https://familywoodworking.org/forums...lacement.3163/
    (Note the model number referenced on that page does not include the "CV" suffix you mentioned.)
    Sep 2003
    1469
    Thanks RS I found those instructions too, where I’m having trouble is separating the darker gray part where the brushes are mounted from the round aluminum lower body of the router. I have removed all the screws from the top of the brush assembly and the left hand nut with the round magnet attached to it.
    I don’t see anything else causing the two sections to stick together other than the friction between the two sections.
    My thought is to make a couple of half round pieces of wood that closely fits the round aluminum body and clamp it lightly in the vice and use a hardwood and hammer to see if I can drive the darker brush holder assemble off. What do you think of that approach?
    I have two hitachi M 12 VC routers and changed the bearings in the other one a few years ago and don’t recall the difficulty in separating these two pieces on it then.
    Hager
  1. Cost to replace bearings ?
    By bhdavis1cnc in forum Spindles / VFD
    Last Post: 04-21-2021, 11:51 PM
  2. Which Spindle Bearings to Replace?
    By cowanrg in forum Benchtop Machines
    Last Post: 08-25-2014, 06:17 PM
  3. Replace Z bearings
    By Gallchobhair in forum Avid CNC
    Last Post: 03-18-2014, 05:20 AM
  4. How to tell if bearings worn on a series 1? How to replace?
    By SRT Mike in forum Bridgeport / Hardinge Mills
    Last Post: 09-10-2009, 03:14 AM
  5. Looking to replace the lathe and mill bearings
    By bprager in forum Shopmaster/Shoptask
    Last Post: 04-08-2008, 02:10 PM
