585,978 active members*
4,377 visitors online*
    dip switch settings
    I am currently converting a G0704 to cnc and I have a KL-5056E Digital Stepper Driver-32 bit DSP Based for the X and Y axis with NEMA23 570oz/in 5A 3/8” Dual Shaft Stepper Motor (KL23H2100-50-4BC). Then a NEMA34 Stepper Motor – 906 oz in 6.1A Dual Shaft (KL34H295-43-8B) with KL-8070D Digital Bipolar Stepper Motor Driver-32 bit DSP Based for the Z axis. I am trying to figure out what I need to set the dip switches to on the drivers. I wired the Z axis motor to be bipolar parallel, and i believe the x and y motors come wired for the same. The x and y motors arrived with the motor cable already installed, the z did not. Everything was purchased from automation technologies. Also I got the aluminum driver/ power supply box from them as well, Do I need to put like a rubber spacer between everything and the box as i mount them?
    Re: dip switch settings
    For the KL-5056E dip switch, you can set to 1-8: OFFFFFOO. For the KL-8070D, you can set to 1-8: OFOFFFOO. (O = ON, F = OFF)
    And thick rubber spacer will be necessary to installed between your breakout board and the box.
    Awesome Thank you very much!
  1. Dip Switch and Config Settings Questions
    By aero1310 in forum Stepper Motors / Drives
    Last Post: 09-11-2018, 02:57 PM
  2. DC860A Dip switch settings
    By Beachcues in forum Stepper Motors / Drives
    Last Post: 02-16-2015, 06:16 PM
  3. Wantai DQ542MA Dip Switch Settings
    By Typefighter01 in forum Stepper Motors / Drives
    Last Post: 08-13-2013, 06:56 AM
  4. Dip switch settings for DL-5056D?
    By ddragon in forum Benchtop Machines
    Last Post: 11-09-2012, 02:21 AM
  5. API P315L Dip switch settings
    By Tego in forum Stepper Motors / Drives
    Last Post: 06-19-2010, 02:22 AM
