585,917 active members*
3,640 visitors online*
Results 1 to 2 of 2
    Aug 2010
    188
    maximum feed rate - sinumerik 840D control
    is there a parameter i can change to set the maximum feed rate accepted by the control?
    need to cut a thread with a 6" lead......
    thanks in advance.
    Sep 2002
    1955
    Re: maximum feed rate - sinumerik 840D control
    I don't think that you can increase the max. feed rate of your machine by just changing a machine parameter. That rather would require more powerfull drives.
    Why do you think that the max velocity of your machine has been reduced unnecessarily during initial setting up?
  1. Replies: 0
    Last Post: 08-05-2019, 03:00 PM
  2. SIEMENS SINUMERIK 840D CNC CONTROL - Error Code 700042
    By zeshan in forum Machinery Manuals / Brochures
    Last Post: 03-23-2018, 09:55 AM
  3. CNC STAR ECAS 32T with Sinumerik 840D control, Alarm 66073
    By Mircea123 in forum CNC Swiss Screw Machines
    Last Post: 09-09-2016, 12:38 AM
  4. sinumerik 840d control
    By kevinwd1 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-22-2016, 09:16 AM
  5. maximum feed rate question
    By george w in forum Mach Mill
    Last Post: 03-05-2009, 12:09 AM
