544,187 active members*
2,782 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > General Fiber Laser Cutting > Help, I am looking for a fiber laser engraver with X-Y table and cutting ability
Results 1 to 2 of 2
    Registered
    Jun 2007
    Question Help, I am looking for a fiber laser engraver with X-Y table and cutting ability
    Hello Folks,
    I already own a 50w chinese CO2 laser machine, but it cannot cut metal. Right now I am looking into buying a fiber laser engraver, partly because this is what I think I can afford, partly because I think (maybe wrongly) that I could use it for cutting maximum 1mm thick stainless (even if fairly slowly and in case there is one with enough power). I saw that these machines can be purchased with an x-y table, which would be great for getting straight cuts . . . in case instead of using the galvo mirrors, just having the beam vertical and move the table underneath instead (use it in x-y cutting mode). Now this is what I know almost nothing about. The machines I see on the net equipped with an x-y table, can they be used as lasercutters, or is the x-y table only ment for holding several parts and engrave them in the same fashion? I hope you know what I mean. How much power is needed to cut 1mm thick stainless? Any advice, also on brands, types, what should I look at etc. would be highly appreciated.
    Member
    Jun 2021
    Re: Help, I am looking for a fiber laser engraver with X-Y table and cutting ability
    Hi dear,This is Flora from Gweike Laser(https://www.gweikecnc.com/)so if you dont mind,may i know your email and whatspp to send you some videos to check it firstly?
    Flora
    flora@wklaser.com
    0086 13275359772
    Hello bro, it requires at least 280W.
    But I'm not an engineer, can not tell you lots of details to build your own one
  1. gweike fiber laser welding and fiber laser cutting machine
    By laserliu in forum General Fiber Laser Cutting
    Last Post: 06-28-2019, 02:59 AM
  2. Fiber Laser Engraver of China Perfect Laser?
    By Alicelee in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 01-20-2019, 01:37 PM
  3. Fiber Laser Engraver, Fiber Marking Machine
    By automationtechinc in forum Automation Technology Products
    Last Post: 07-18-2018, 10:39 PM
  4. Fiber cutting ability from 300w to 1500w
    By Gweikelasers in forum General MetalWork Discussion
    Last Post: 04-09-2017, 07:10 AM
  5. Cutting ability for different matieral of different fiber power source
    Last Post: 03-29-2017, 03:09 AM
