586,011 active members*
4,212 visitors online*
    Jun 2021
    Poor cutting on Y axis
    Hello people - an unusual issue using a 2 axis EleksMaker Motherboard
    Something to get the Electronic Wizards out there thinking.
    the Basic problem
    I am cutting a SQUARE from a piece of ply with a high powered dual diode laser module & its dedicated controller.
    My laser puts out about 30% LESS power when moving front-to-rear in the Y axis direction
    Y drives 2 motors... so logically I thought was that the laser is being starved of power...
    Nope... wrong again...
    Part way thru the Y movement I pulled a Y motor connection & the laser instantly puts out the same/proper power as when moving in the X direction - left to right...
    so, I fitted a 10 amp 12 volt power supply for the motherboard & laser, and hooked up an external stepper amplifier solely to drive the two Y motors - with its own 12volt 10amp power supply.
    This external stepper amplifier is capable of driving BIG Nema23 motors or bigger, and has no problem driving a pair of Nema17 motors.
    The same issue occurs, that the laser is weaker in Y direction...
    So again I pull a single Y motor connector & the laser instantly pushed more power & makes the cut.
    The motherboard & laser have one 10 amp power supply
    AND
    the Y motors have ANOTHER 10 amp power supply via the stepper amplifier,
    yet the laser still drops power in Y direction unless one Y motor is unplugged mid run...at which point the laser resumes a clean cut again.
    The two powers supply units work, and the only electrical connection between the stepper amplifier and the motherboard are the signal feeds to control the external Y motors amplifier.
    I have swapped out the Y motors for smaller lower powered units, swapped out the motor cables, swapped out the mother board & multiple nano-boards.
    It seams like there is some electrical interference (RF or Capacitance) that is feeding back from the dual Y motors that is interfering with the laser signal....
    So,
    I fitted ferrite rings to the motor cables - to all 3 motors, and to the power supplies, and the laser signal cable from the Motherboard to the Laser control module...
    and still the laser reduces power in the Y direction.
    Has any one got any ideas on this & what could solve the problem.
    Nov 2008
    644
    Re: Poor cutting on Y axis
    If you swapped the X and Y motor connectors does the problem follow the X axis?
  1. Replies: 2
    Last Post: 05-25-2022, 01:23 PM
  2. poor cutting results
    By tosho82 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-15-2020, 03:29 PM
  3. Poor circular cutting issue
    By Jonasforssell in forum Benchtop Machines
    Last Post: 04-13-2013, 07:29 PM
  4. BF20 (G0705) Power Draw Bar Build (Poor, poor mans drawbar)
    By zerodegreec in forum Benchtop Machines
    Last Post: 09-14-2010, 09:01 AM
