585,987 active members*
4,621 visitors online*
    Oct 2010
    7
    Denford Easiturn 3 Lathe Help Needed
    I've just bought a Denford Easiturn 3 Lathe. It's been converted to run on Mach 3. I bought it as a 'Might run but will need a bit of work doing on it', The guy I bought it off was running it (as he told me, Sounded genuine), His 'mate' cam along & went cut, cut, cut, saying you don't need this or this or this etc, etc.
    The obvious He sold it.
    I asked my mate a qualified electrician to have a look, He's actually a TV engineer but is into stuff like this & has fixed my Interact for me on a few occasions.
    He told me that he'd have a look BUT 'didn't know what he was looking for or what stuff was meant to do' I explained vaguely, very vaguely. I made him a cuppa & went away as he told me to, about an hour or 2 later he's asked me to come out to my workshop. I've never worked nor seen Mach 3 before, I turned it on (touch screen) played around with a few buttons & got it working by Jogging & MDI, I checked the position & it kept going back to the same position all the time, I'm well happy so far It's retuning bang on every time to the same position. enough for the day.
    Turn off.
    Next day I'm doing exactly the same (Yes I've downloaded a Manual) & am using it.
    I'm jogging in Z it's stopped, I don't know what I did it started again, But would only go -Z (Towards the chuck). It's carried on like this, Even when I've pressed +Z on the few occasions that it's moved it's always on in the -Z , I've removed what looked like a stop (block of metal clamped to the bed looked like it was put there to stop tool post crashing into chuck.
    Now it won't move at all & I'm getting the message "Soft Limits System Movement Aborted"
    What have I done? run over a stop, How do I get out if this Please, Thanks, I advance for any help, which will be greatly appreciated.
    Aug 2015
    32
    Re: Denford Easiturn 3 Lathe Help Needed
    Quote Originally Posted by Barrie View Post
    Turn off.
    Hi not sure if youve sorted this but it sounds a bit like my denford zeroturn . you need the stop ramp to be there. sounds like you have not homed the machine properly after re starting the machine. I dont know anything about mach as mine has the original fanuc system but would imagine you need to
    home machine same as most cnc machines when you first start up.
    Oct 2010
    7
    Hi Thanks for reply, I thought I did all that they said But I will look into this, I've not done anything else since I posted here & elsewhere to see what replies I get, I can't see any point in digging further into the hole, Thanks, I'll try what you've suggested, I have been told with Mach 3 is that you don't need to ref M/c out each time you start up, I find this hard to believe as I'm no expert on CNC but I'm not green either & I've not come across this before, Thanks, Stay Safe, Barrie.,
    Aug 2015
    32
    Please post your results be it positive or negative.
    regards
    Phil
    Aug 2015
    32
    Just another thought reading your original post I did have some issues myself when I tried to wind the slide manually past one of the stops.
  1. Replies: 8
    Last Post: 08-21-2015, 07:43 AM
  2. Replies: 0
    Last Post: 01-27-2015, 02:31 PM
  3. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  4. Help With Project Needed - Guru Needed Please
    By cuetipper in forum DIY CNC Router Table Machines
    Last Post: 12-03-2012, 10:58 PM
  5. RFQ needed...parts needed ASAP
    By billet works in forum RFQ (Request for Quote)
    Last Post: 10-12-2011, 01:39 PM
