586,009 active members*
4,855 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Macro Variable value Driven Variable
    Jun 2004
    7
    Hi All,
    Sorry folks not even sure how to explain this one.
    The following is dummy code to try and solve an issue I have.
    I'm trying to refer to a variable using a different variables value to set the variable name.
    POS1=20
    VC20=123.4
    PXM=VC[POS1]
    Does PXM Equal 123.4?
    in Fanuc you use ##
    Apr 2006
    822
    Re: Okuma Macro Variable value Driven Variable
    Quote Originally Posted by ablackwell View Post
    Hi All,
    POS1=20
    VC20=123.4
    PXM=VC[POS1]
    in Fanuc you use ##
    Short answer is YES!
    expanding the line PXM=VC[POS1] becomes PXM=VC20
    Jun 2015
    4154
    Hy ablackwell, that little code is too simple for your experience; if i may, sometimes, is faster to test, rather than asking for help
    trial testing is key and a huge time saver
    i dont know what you are trying to do, but you take it step by step : ifsyntax, file asignment, variables with arguments, etc
    Apr 2006
    822
    Quote Originally Posted by deadlykitten View Post
    Well Kitty, Asking a simple question can often save lots of time in testing!
    Maybe he didn't have access to the machine for testing?
    Anyway, not always necessary to know what the person is ultimately trying to achieve, a quick, simple reply is all this person asked for and that is what I provided.
    YOU have asked plenty of questions in the past.
    Cheers
    Brian.
    Jun 2015
    4154
    you are correct i am not saying that there has to be a single approach, but after writing a code, less keystrokes are required to test it, rather then whatever else
    timing is key, and osp has the capability to allow dense testing by using network,etc ... other brands require a too long keychain, that simply delays testing, and somehow may discourage someone, like using that crowded fanuc keyboard, or the ';' , etc
    such things may make someone to imagine that what he learned is the only way, while osp is so much more
    very few people ask the questions that he does, in such a short time window, thus there is experience, but there is no speed ...
    is not needed to be near a cnc to test an okuma macro, as long as there are no system variables
    and in some cases , having acces to data logs, leads to useless discusions, that otherwise wouldnt happen if monitoring tools wouldnt have been used / kindly
  1. Looking for the macro variable no. For.....
    By gavintwopies in forum Daewoo/Doosan
    Last Post: 10-31-2020, 03:20 PM
  2. Macro variable name
    By positiverake in forum Fanuc
    Last Post: 10-27-2020, 06:32 PM
  3. Assigning post variable to Vbscript variable
    By vfsi in forum BobCad Post Processors
    Last Post: 10-18-2016, 01:30 PM
  4. macro b local variable
    By samu in forum Fanuc
    Last Post: 12-19-2010, 12:55 AM
  5. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
