I am wondering if there is a 110/120 power outlet or source inside the cabinet on the haas that can be controlled with M-code or control panel settings?
I do have an outlet on my electrical cabinet
I have rigged up a small transfer pump that I use to help get coolant from inside the machine back down into the coolant tank. I was constantly fighting plugged drains on my mini mill, so I just added this transfer pump and it solved the problem.
But I don't want it to run constant.... I want to have it turn on and off similar to my chip auger which is currently controlled by settings ( I can't remember, but I believe its a setting on the control panel )
The mini mill has a tank that is part of the frame, so getting that drain pan clean of chips is a nasty time consuming job..... so that's why I went the route of the transfer pump.
Kent
