585,981 active members*
4,288 visitors online*
Results 1 to 10 of 10
    Aug 2004
    7
    Elox-Fanuc wire cut series Q Issue
    Hi, We have an Elox-Fanuc wire cut series Q, It will run a program complete in dry run but when you execute it normally it stops about 4 lines into the program on the first G01 command line and just sits there. Any idea why? Its ran these same programs before without issue. I also need a copy of the schematic for this machine. Does anyone have one? Any help is greatly appreciated.
    Aug 2008
    406
    Re: Elox-Fanuc wire cut series Q Issue
    did you fix this ?
    Aug 2004
    7
    Quote Originally Posted by gabedrummin View Post
    did you fix this ?
    No, we still have the problem. It seems like the power for the cutting wire doesn't come on. The wire is rolling but no cut power. We did find the schematic but its pretty archaic.
    Aug 2008
    406
    First thing I would check if the wire is shorted out somewhere along the path . If the wire touches something other than the part you are trying to cut .When you push the power button do you hear the generator latch in / With the power on you can use an ohm meter to check between the the wire and table for voltage .You can also use the meter to see if the wire is shorted the table .There should be no continuity between the wire and work table .Did the machine ever work ?
    Aug 2004
    7
    Yes, I worked fine. I'll do the ohm checks and see if theres any continuity
    Aug 2008
    406
    I have had some issues where the wire that go thru the felt pads was touching the shaft causing a short . You can also have a short inside a head . Dose your edge find word ? If it works correctly you can rule out a short.
    Aug 2004
    7
    Not sure I'll have to ask. The machine is at another location. Be a couple days before I can get back to it.
    Aug 2008
    406
    If your edge find dose not work your problem is a short .You also have two small micro switches that tell if the wire is broke if they are damaged or not touching the wire the machine will no run .What state are you in?
    Aug 2004
    7
    Racine Wisconsin
    Feb 2022
    Did you fix it? I have an Elox Fanuc Series Q with the same problem.
