3 / 4 AXIS CNC MOTION CONTROLLER (500KHZ) DDCS V3 CNC CONTROL
https://www.youtube.com/watch?v=8gqWXBfoJKM
Product Link:
https://www.automationtechnologiesin...ntroller500khz
Description:
CNC Motion Controller 500KHz Stepper Motor Driver DDCS, 4-Axis MPG
The DigitalDream CNC has engaged in the numerical control industry for 7 years, specializing in the research, development and production work of various CNC (Computer Numerical Control) systems with high quality, high reliability. It can produce the common Brushless DC motor, Stepper motor driver as well as the 1 axis CNC system to 6 axes CNC system.
The DDCS is the 4 axis and 4 axes motion controller which has been researched and developed by Faster CNC for four years. The control period of each position is only 4 milliseconds, with a high control precision. The highest uniaxial output pulse is 500KHz and the pulse width can be adjusted. It supports the common stepper motor and servo motor.
The DDCS numerical control system adopts the ARM+FPGA design framework. The ARM can finish the part of human-computer interface and code analysis and the FPGA can finish the part of underlying algorithm and control pulse generate, with the reasonable design, reliable control and easy operation.
The panel layout structure of DDCS is rational. The common off-line operation can be finished only by 17 keys and it supports the FANUC with high universality to be compatible with G code set. This specificationintroduces the operation method of caving machine’s special off-line CNC system, DDCS and the machine tool connection as well as operation specification. By lots of graphical representation and examples, the uses can quickly learn to use the DDCS CNC system.
DDCS has made the following changes on the basis of DDCS:
1:The input signal is modified to support the NPN switch;
2: Support limit and the home share the input port;
3: Use the more stable FLASH, to ensure that no program loss;
4: Upgrade algorithm, support soft interpolation, modified V1.1 version of arc
interpolation bug;
5: Upgrade the power module, the system is more stable
4-Axis MPG
The CNC 4 Axis handheld controller MPG Pendant handwheel with x1, x10, x100 selectable, You are bidding one complete unit of the MPG pendant with Emergency stop for 4 axis CNC machine, it equipped with our popular machined MPG unit with 4 axis and scale selector, LED indicator also send feedback from the CNC machine to user about the status of the unit.
- All Wiring isolated from MPG unit and provide a easy to install wiring diagram, it suit both commercial machine as a replacement jog control unit or other computer based controller. Which add great control flexibility to the system.
Features :
- x1, x10, x100 switch
- X,Y,Z,4th axis selector switch
- LED indicator
- With Emergency stop
- High quality professional chassis
- 6ft extendable high quality shielded cable cord
- Magnetic base holder can place anywhere on the machine steel surface
- Required 5V+, 150mA, power for MPG
- Phase output is A ,/A and B,/B;
- TTL output, drive capability +-20mA;
Support CNC System:
Taiwan Pou Yuen M600 M500 M520i T300 series, Higerman, HANUC,GSK,opened NC, KND,S, the NUM, Spain FAGOR (NEW, 8055I) and so on.
Wiring:
User can wire this unit to the CNC system.
User Manual:
Package included:
- 1 x 4-Axis CNC Motion controller
- 1 x 4GB USB Flash drive
- 1 x USB Extension Cable
