585,880 active members*
8,015 visitors online*
    Weeke import 3D dxf
    Using Wood WOP 4.5.
    We have had good success using the dxf import function in WoodWOP. I can bring in contour lines or hole into WoodWOP using the pdf file. I have even managed to import tool paths from other CAM software as long as I can output the path in a dxf. It took some tweeking in the BPP.ini file to get it to work correctly.
    What I can't do is import 3D lines. The woodWOP file is not accepting the Z coordinates from the dxf file. Had anybody else had any luck importing 3D dxf files?
    Quote Originally Posted by Hopefulbull View Post
    Using Wood WOP 4.5.
    Here is the BPP.ini file I'm using in WoodWOP to help import DXF files. The DXF needs to have the correct layer names for the import to work correctly.
    I just can't get it to import 3D lines. Let me know what I'm doing wrong.
    Ting to attach.
    Apr 2004
    5737
    Re: Weeke import 3D dxf
    Is IGES (or igs) an option? That's a more common format for 3D splines than DXF, which is usually just for flat lines, curves, and arcs.
    Andrew Werby
    Website
    Jul 2018
    31
    I am unable to see the attachment.
    Sent from my Redmi Note 4 using Tapatalk
  1. dxf import
    By Ronin26 in forum Mastercam
    Last Post: 11-09-2013, 11:37 PM
  2. Import DXF
    By Nat Wheatley in forum BobCad-Cam
    Last Post: 02-08-2009, 09:51 PM
  3. DXF Import
    By Martin Long in forum Syil Products
    Last Post: 07-14-2008, 04:38 AM
  4. import DXF
    By qmas99 in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2006, 01:08 PM
  5. DXF Import
    By Todd Price in forum Rhino 3D
    Last Post: 06-07-2004, 06:24 PM
