584,865 active members*
4,940 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Best Gantry Linear Rail Configuration ?
View Poll Results: What is your preferred Gantry Rail Config?
Voters
4. You may not vote on this poll
  • 1
    1 25.00%
  • 2
    1 25.00%
  • 3
    1 25.00%
  • 4
    0 0%
  • 5
    0 0%
  • 6
    1 25.00%
Multiple Choice Poll.
Results 1 to 7 of 7
    Apr 2020
    50
    Apr 2020
    50
    Re: Best Gantry Linear Rail Configuration ?
    Interesting..
    280+ views and no opinions on what would be the better gantry rail configuration.
    Maybe I made the question to hard or confusing..
    Sep 2005
    1195
    I use no. 4 design on all my cnc router based on force work vertically or horizontally ...
    Jan 2008
    1523
    There is no "best" in machine design.
    Ever decision is a compromise.
    4/5/6 have advantage in resisting torsion. Downsides include more difficult to machine and align. And you have to make sure the carriage mounted to bearings is appropriately rigid.
    Aug 2015
    142
    Interesting point with torsion , but why 3 is not better tan 3 or 4 , why in industrial machines there is aproximatley all time used 3 ? How can be more resistant to torsion 456 than 3 or 2 or 1 ? Because there are same dinamic range , and same boxes .
    Apr 2020
    50
    Thanks for your feedback
    Jul 2018
    6254
    1) Is good because the "crank centre ie the line of action of the resulting car reaction moment" is through the shear centre of the section so will resist torsion well. Its bad because its harder to machine opposing surfaces and the rails are mounted on "air" so they can vibrate
    2) Same reasons as 1) but now they are mounted on long thin surfaces so will vibrate worse. Plus the forward car makes the stack height of the Z more then 1)
    3) common arrangement easy to machine rail lands. Poor because the crank centre is not through the shear centre so resisting torsion and bending is not efficient
    4) & 5) not easy to machine lands, no advantage in Z stack,
    6) rails on edges is better then in middles of flats, crank center is near shear centre. Move bottom rail to bottom of section, near fwd edge and it will be better again as the rails are then furthest apart. Peter
  1. Replies: 0
    Last Post: 09-05-2019, 06:20 PM
  2. Open Rail DIY Linear V Rail System
    By kram242 in forum News Announcements
    Last Post: 06-11-2012, 03:33 PM
  3. What linear rail for new gantry?
    By Txchevy in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-13-2012, 08:31 AM
  4. One truck per rail configuration: Okay?
    By sp1nm0nkey in forum Linear and Rotary Motion
    Last Post: 01-10-2012, 08:07 PM
