585,737 active members*
4,717 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Bearing info? MultiCAM 1000 Router 1-103-R
    Hey Guys;
    I've replaced the linear bearing blocks on my machine which I thought were causing a creaking noise but of course using a stethoscope I now realize its the noise is from the bearings in the stepper gearboxes themselves. MultiCAM Canada has confirmed there are two bearing in each motor gearbox install. Maurice thinks they are common bearings likely 6202 but he's not sure of that number. Although that number corresponds well. I went ahead and ordered them from MultiCAM just in case but its been 3 weeks now and the last I heard from them was that they were still waiting to hear from their vendor before giving me a ship date. I'm already very likely overpaying for the parts which is OK if the service is there but ........
    Does anyone know what these bearings are or can confirm Maurice's # or something I can cross reference as I'd like this fixed ASAP.
    MC Canada describes them as; "bearing ball 15mm id35 OD snap ring"
    Mike
    www.classicplayfields.com
    Dec 2013
    5717
    Re: Bearing info? MultiCAM 1000 Router 1-103-R
    You might want to open up the gearbox and take a look, it's a pretty simple job. The last time I saw this happen the bearing spun in the housing and I had to use some Loctite bearing mount to repair. Once you're in there, the bearings should have numbers on them and your local bearing vendor should be able to get them at much less cost than MultiCAM.
    Jim Dawson
    Sandy, Oregon, USA
    Just after I posted this MC Canada sent them out and I received them 3 weeks after I ordered them... express though. Good thing I wasn't down and waiting on these bearings. The bearings they sent were NSK 6202DU
    Mike
  1. Multicam CNC Router 1000 series
    By FSSchmidt in forum CNC Machine Related Electronics
    Last Post: 02-28-2019, 07:27 PM
  2. Replies: 6
    Last Post: 05-22-2012, 12:54 AM
  3. Multicam CNC Router Series 1000 User Manual
    By cdemarchena in forum Machinery Manuals / Brochures
    Last Post: 01-28-2012, 08:41 PM
