585,902 active members*
4,251 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Automation Manager and Materials (number of sheets)
    Dec 2004
    22
    I've been working on this for weeks....
    I can't seem to figure out how to utilize some offcuts for my nested parts. Originally I thought it would be as simple as entering the sheet sizes into the Materials tab of the Automation Manager and entering the quantity of each sheet size.
    Automation Manager ends up nesting everything into the first sheet size regardless of the quantity. Any comments on what I am doing wrong?
    Dec 2004
    22
    Re: Automation Manager and Materials (number of sheets)
    Quote Originally Posted by granto View Post
    The problem I have isn't an issue if I use the Nesting function. It's only when I use the Automation Manager that this is an issue.
    At the moment, I process all the parts using the Automation Manager and then use the .ard files and nest them with the nesting function. This bandaid solution is working but I can't see why I'm having a problem with the Automation Manager...
    Dec 2004
    22
    As an update. I reached out to Alphacam support for an unrelated issue with Alphacam 2022. He agreed that this material thing looks like an issue and will open a support ticket for me. I hope it leads to a solution.
  1. Replies: 0
    Last Post: 11-17-2015, 05:53 PM
  2. Machine Manager CNC and Automation Framework
    By bradodarb in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-06-2013, 04:16 PM
  3. Machine Shop Manager - Haas Automation
    By Haas_Apps in forum Employment Opportunity
    Last Post: 12-09-2011, 02:52 PM
  4. Machine Shop Manager / Automation Specialist - Chilliwack, BC
    By EOCanada in forum Employment Opportunity
    Last Post: 10-09-2010, 03:09 PM
