585,974 active members*
4,368 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD
    May 2018
    Question. What are the control circuit connectors used on these VFD's called? I think the pin spacing is 2.4 or 2.54 mm. I bought this VFD from Surplus Center and it came without the screw terminal connectors.
    May 2018
    Re: FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD
    Could not get much info from Surplus Center. I finally found someone at FUJI that told me that these VFDs were programed for a specific machine and were not able to be used otherwise. All I could get it to do was power up, but could not change any settings and could not get power out to the motor. Sent them back and got a refund.
  1. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
  2. Can a 3ph input VFD Hitachi J100 run on 1ph ?
    By maquiza in forum Phase Converters
    Last Post: 05-26-2009, 04:55 PM
  3. running a 1PH motor on a 3PH converter
    By bmachinist in forum Phase Converters
    Last Post: 11-27-2007, 03:07 AM
  4. 3ph to 1ph help
    By actionman in forum Welding Brazing Soldering Sealing
    Last Post: 04-14-2007, 10:30 PM
  5. Can a 3ph input VFD run on 1ph ?
    By Don Lester in forum Phase Converters
    Last Post: 06-27-2006, 06:51 PM
