585,763 active members*
4,484 visitors online*
    May 2017
    7
    install new 90w co2 laser tube
    Hello
    Can i install new 90w co2 laser tube, on machine with 120w laser power supply.
    Thank you.
    Nov 2008
    644
    Re: install new 90w co2 laser tube
    I’ve run a 50w tube off a 60w power supply for years. I’m careful that I don’t overdrive the tube by staying safely under the max milliamperes specification of the tube. So you need to have a meter on the tube.
    There may be other considerations to consider when matching power supplies to tubes, besides power.
    May 2017
    7
    Thank you for reply. But I'm still confused about this installation.
    Apr 2018
    20
    Yes you can.Usually higher power PSU can take low power laser tube.But the trigger current is different.So it is not good for long term using.
  1. Need help: install new 90w co2 tube laser
    By Evoart in forum Laser Hardware
    Last Post: 01-02-2022, 04:33 PM
  2. Laser tube and power supply 40W co2 and 60w co2
    By Yaro in forum RFQ (Request for Quote)
    Last Post: 07-18-2014, 08:36 AM
  3. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  4. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
