585,996 active members*
4,722 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang GT Series VFD keypad Pot does nothing
Results 1 to 14 of 14
    Jan 2021
    5
    Looking for help setting parameters on a HY GT Series 5.5kW VFD driving a 1.5kW 220V 6A 24000rpm air-cooled spindle. I'd like to control the spindle speed from the pot knob on the keypad. I'm having 2 issues when while setting up:
    1. With basic spindle parameters set, and pressing Run the spindle accelerates to about 7200rpm and frequency = 120hz (keypad reference frequency) , but turning POT knob has no effect.
    2. Attempting to Auto-tune, the VFD accelerates to a constant frequency and after a minute or so, stops and shows EEP error.
    My settings are:
    P0.00 0
    P0.01 0
    P0.02 0
    P0.03 400
    P0.04 400
    P0.05 120
    P0.6 0
    P0.07 0
    P0.09 0
    P0.10 0
    P0.11 10
    P0.12 10
    P0.13 0
    P0.14 6
    P0.15 1
    P0.16 0
    P0.17 0
    P1.00 0
    P1.01 10
    P1.02 0.0
    P1.03 0.0
    P1.04 0.0
    P1.05 0
    P1.06 0
    P2.01 1.5
    P2.02 400
    P2.02 24000
    P2.03 220
    P2.04 6
    Any ideas on what is wrong?
    15362
    Re: Huanyang GT Series VFD keypad Pot does nothing
    Quote Originally Posted by hawillk View Post
    My settings are:
    P0.00 0
    P0.01 0
    P0.02 0
    P0.03 400
    P0.04 400
    P0.05 120
    P0.6 0
    P0.07 0
    P0.09 0
    P0.10 0
    P0.11 10
    P0.12 10
    P0.13 0
    P0.14 6
    P0.15 1
    P0.16 0
    P0.17 0
    P1.00 0
    P1.01 10
    P1.02 0.0
    P1.03 0.0
    P1.04 0.0
    P1.05 0
    P1.06 0
    P2.01 1.5
    P2.02 400
    P2.02 24000
    P2.03 220
    P2.04 6
    I will see what Parameters you need for the pot to work
    You can't auto tune with this VFD Drive with a 400Hz spindle, and they only auto Tune when in vector mode with a lower frequency motors
    Mactec54
    15362
    P0.06=400
    J1 Jumper Pins 1-2 for Pot control
    Mactec54
    Jan 2021
    5
    Just set P0.06 to 400hz, but now it accelerates to 400hz immediately after run. It looks like the J1 1-2 Jumper was pre-installed. Below is how the J1 jumper was set initially (Left edge). I also tried removing the lower jumper, and removing both jumpers. But the POT still has no effect.
    15362
    Each Jumper has a function so you can not remove them completely, they have to be on the correct Pin set for the different functions to work
    I see just pins with no Jumpers on them they need to have the Jumpers on the correct Pins to work
    Try the Up /Down Arrow keys for speed change
    Mactec54
    15362
    Also Try P0.02=3
    Mactec54
    Jan 2021
    5
    I changed P0.02 to 3. The POT still doesn't work. However, the arrow buttons work fine. From here on, I can accept setting a "keypad reference frequency" P0.06 to a typical value and using the arrow buttons as needed. I appreciate all of your help so far.
    Attaching picture of the J1 jumper set-up circled because they were hard to see/find. These jumpers are only accessible after removing the upper cover that has the keypad bay.
    15362
    No P006=400 it should always be 400 is what the key pad then knows what your max speed can be, the Arrow up/down will then control /set what speed you chose to run at
    Strange place to have the J1 Terminal it is normally next the the main logic terminals on the front of the VFD Drive no covers are removed normally to access them
    Mactec54
    Jan 2021
    5
    I did notice a red led solid on inside the VFD just visible though the vents. I can't find any mention of it in the manual. Could this indicate a problem? Would it be related to the POT not functioning?
    15362
    No there will be a Parameter that gets the Pot working try
    P0.07=7
    Mactec54
    Jan 2021
    5
    P0.07 = 7 Didn't work. The manual names this param "Frequency A command source". 7 is for remote communication. Just tried P0.07=1 (AI1) And it works! It appears the POT on this VFD sets voltage on Analog Input 1. I had tried this setting previously, but may have had other settings incorrect.
    Currently, P0.02=3 P0.06=400 and P0.07=1 and the POT functions as expected. I really appreciate all the help!
    Aug 2009
    1573
    ...if, you have J1 Pin3 and 4 jumper AI1 is Active and P9.0 Group may need adjusted..... maybe mactec can explain how it affects anything.
    15362
    Yes as I said it was to do with that Parameter P0.07 it was just a matter of trying each Parameter number to see which one worked, most that use this VFD Drive don't use the Pot so I don't no of anyone using it before for this GT series so now we know which Parameter number to use, why I said to try that number is because the Pot is considered remote
    Mactec54
    15362
    Make sure you set Parameters for overvoltage and over Amps they are normally a % Parameter setting this will help to protect your spindle with using that large Kw VFD Drive
    Mactec54
  1. Huanyang GT Series VFD and MASSO
    By Matt-y in forum Spindles / VFD
    Last Post: 12-04-2020, 12:53 AM
  2. (Yet another) Huanyang VFD settings questions for GT series
    By andyjack38 in forum Spindles / VFD
    Last Post: 11-23-2019, 08:11 PM
  3. changing Huanyang HY to GT series VFD
    By PJRU0304 in forum DIY CNC Router Table Machines
    Last Post: 04-15-2019, 04:34 PM
  4. Huanyang VFD Issue pot not going past 25hz.
    By gomviandres in forum Spindles / VFD
    Last Post: 10-10-2018, 08:29 PM
  5. Replies: 4
    Last Post: 06-21-2018, 12:15 AM
